Ferrino's Avatar
Amber Fiberglass Effect
Does anyone have any insight into how the various amber fiberglass reproductions of fan shrouds and engine tinware are made, please? Is this done with a specially tinted fiberglass resin or can you modify a generic resin with some sort of tinting agent? There is a natural yellow tint to the polyester resin I've used in the past, so maybe some of them are just virgin resin?
Old 11-24-2015, 12:52 PM
Diss Member
Quicksilver's Avatar
There are plenty of different ways to color resin. For some of them it depends on if you are using polyester or epoxy resin. A simple google search shows a bunch of choices.
Here is a real interesting article by West Marine about various pigments used with epoxy: WEST SYSTEM - Projects - Adding pigments to epoxy
Interesting bit is it appears you can use almost anything with epoxy and not seriously effect its strength. (They even list using Rit dye at a 20% concentration!)
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 11-24-2015, 02:20 PM
Charles Freeborn's Avatar
TransTint Liquid Dyes - Homestead Finishing Products
Beware, it's really potent. A few drops goes a very long way.
-C
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 11-24-2015, 04:10 PM
Senior Advisor
James Brown's Avatar
i would like a clear one
08 Cayenne Turbo
Old 11-24-2015, 05:28 PM
Ferrino's Avatar
Thanks. What about the fiberglass material used - some (like the one pictured) you can see it uses cloth, while others I've seen appear to use chopped strand mat.
Old 11-25-2015, 09:59 AM
Banned
Add to that that they use Kevlar as the cloth - Kevlar has sort of a light yellow/amber color to the fibers.
Old 11-25-2015, 10:14 AM
85911's Avatar
fiberglass resin
I have recently used West System's epoxy on a project that specifically is formulated to be used with fiberglass cloth and is clear. The fiberglass cloth is white, but it "disappears" when it is saturated with the resin. The finished product is very durable and strong.
1985 911 Carrera Targa, 2011 911 Carrera S 997.2, 1951 Harley Davidson Panhead Chopper, 1957 Harley Davidson Panhead- stock, 1972 Yamaha 250 DT-1(sold), 1959 Austin Healey (Bug Eye) Sprite- sold, 1959 Austin Healey (Bug Eye) Sprite- sold, 1960 Austin Healey (Bug Eye) Sprite- sold
Old 11-25-2015, 10:34 AM
Chromo
Guest
Posts: n/a
Hi Ferrino,
The amber colour is natural resin over glass cloth, with no gel coat. I'm assuming they did this to save weight. Back in the day, I'm assuming there were no tinters in the resin, whereas nowadays you may struggle to find a raw resin without a colour added. I would call a few suppliers and ask if they can recommend something.
I would avoid Epoxies with hand laid up parts in an engine bay, as they tend to soften with heat (unless they have advanced significantly since I used them 10 years ago). I would go for polyester, or better still, vinylester resin.
Old 11-28-2015, 08:21 PM
