gtc gtc is offline
abides.
gtc's Avatar
Non-paper front HVAC hoses?
Anyone know if the smaller diameter HVAC hoses (36mm & 38mm) are available in the new plastic coated material like the 60mm rear heater hoses?
I need to replace a bunch of moisture damaged & mildewy crappy paper coated hoses in the front trunk and under the dash.
This the style i'm looking for:
(Bonus points for anyone who guesses the Pelican moderator in the background)
Graham
1984 Carrera Targa
Old 10-23-2015, 02:19 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Try an Aircraft Supply company.
'85 Carrera Targa
PCA/POC
Old 10-23-2015, 04:01 PM
I think folks have used this:
Ducting from Aircraft Spruce
Old 10-23-2015, 04:06 PM
gtc gtc is offline
abides.
gtc's Avatar
Yeah, I've used that before, but none of it is actually a good fit since it's sold in inch sizes.
I gave up on using SCEET for the air duct to heat exchangers because 2.5" is loose on the 60mm shroud/heat exchanger ports. Plus it's kind of a bother to cut.
Also, at $10.55/ft for 2.5" SCEET, it's not really any cheaper than buying one of the long Porsche heater hoses and cutting it into smaller pieces.
Graham
1984 Carrera Targa
Old 10-23-2015, 04:58 PM
non-whiner
mreid's Avatar
Try McMaster Carr.
"Too much is just enough."
Old 10-23-2015, 06:36 PM
