-   -   Side window seals confused?? (http://forums.pelicanparts.com/porsche-911-technical-forum/889084-side-window-seals-confused.html)
irl 10-29-2015 10:17 PM
I have a 75 side door with no side window seals and can't find a thread that helps me. On a new build I have put new felt channel inside the window frame but I can't understand the two pieces that go inside and outside along the window on top of door. The PET is confusing and when I look through parts on various sites I see rubber scrapers and felt pieces but various options. My 71 looks like it has felt inner and outer but I see a lot of rubber options online. Any help would be appreciated.
irl 10-30-2015 03:33 PM
After tearing apart my 71, here is a cross section. Now to determine A, B, C, and trim clip parts
http://forums.pelicanparts.com/uploa...1446244344.jpg
RSTarga 10-30-2015 04:05 PM
A, clips onto your door
B, has clips that go into the door and
C slides onto the scraper. Don't cut it until you've put it on the door to verify the length
irl 10-30-2015 04:10 PM
I know that now that I have taken one apart :) Need to find the parts. Everybody calls them something different with diff part numbers and nobody has them all.
irl 10-30-2015 07:31 PM
http://forums.pelicanparts.com/uploa...1446258712.jpg
irl 10-30-2015 07:37 PM
Here is the part numbers as shown on the PET.
fuzzy outer seal
Right 901-531-936-20
Left 901-531-935-20
Scraper outer seal
Right 911-531-932-02
Left 911-531-931-02
Inner fuzzy seal
Left and right 911-531-951-01
Door Moulding clips
999-591-326-01-M100
Qtr window seal strips
901-531-933-20
