Side window seals confused??
I have a 75 side door with no side window seals and can't find a thread that helps me. On a new build I have put new felt channel inside the window frame but I can't understand the two pieces that go inside and outside along the window on top of door. The PET is confusing and when I look through parts on various sites I see rubber scrapers and felt pieces but various options. My 71 looks like it has felt inner and outer but I see a lot of rubber options online. Any help would be appreciated.
79 SC unmolested 75 911 backdated RSR widebody 71 911T having fun skinny 63 356 outlaw frustrating purists 25 GTS |
After tearing apart my 71, here is a cross section. Now to determine A, B, C, and trim clip parts
A, clips onto your door
B, has clips that go into the door and C slides onto the scraper. Don't cut it until you've put it on the door to verify the length
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
I know that now that I have taken one apart
Need to find the parts. Everybody calls them something different with diff part numbers and nobody has them all.
Here is the part numbers as shown on the PET.
fuzzy outer seal Right 901-531-936-20 Left 901-531-935-20 Scraper outer seal Right 911-531-932-02 Left 911-531-931-02 Inner fuzzy seal Left and right 911-531-951-01 Door Moulding clips 999-591-326-01-M100 Qtr window seal strips 901-531-933-20
