Black and Blue
New High Torque Starter...sounds funny to me
Just installed the High Torque Starter I bought here at PP. Installation was easy enough but when I went to crank the motor over, I got this high pitched sound which to me sounded a little odd. Is this just the way the starter motor sounds or did i get a bad one? Everything turns over fine and car starts, etc..
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
I got one for my car a few years ago, works great but it does sound different.
68 911 T Ya lop eared Varmit |
Reiver
It is a high torque dingus because of the gearing and that will sound different...higher whine.
De Oppresso Liber Strength and Honor 5th Legion |
Yup.....normal for the high torque. You'll get used to it.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
yeah they sound like I'm starting a Japanese car to me.
Chris '75 911s Targa |
Even as a certified weight freak at 2174 lb, I had to take mine out after a month and put the Bosch back in. It just sounded wrong. I stopped going to Taco Bell to help compensate for the original one.
Tru6 Restoration & Design |
Chain fence eating turbo
They sound like a Dodge, a Japanese, or high CR drag car. I like the way it sounds. Sounds racecar!
Reiver
Ok, so you really care how your starter sounds?
It is lighter, uses less electrical juice, takes up half the space, starts the car.
good!!! ![]() ![]()
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
I did one on my Alfa GTV, and it sounds like I'm starting an American big block. Definitely a different sound, but worth it for the benefits.
sounds different, but does the job and is significantly smaller and lighter
The main thing I noticed with mine was that my SC fires instantly now, as opposed to the old Bosch unit, which needed a rotation or so to fire (same battery).
Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe |
Black and Blue
as long as it works I'm not too terribly concerned about the sound. I was just making sure that the higher pitched whine is normal for this starter. It is lighter. I had to fab up a way to connect the two harness wires to the single post. And I had to re-route the hot wire to make up for the distance. The only challenge was getting the wires bolted on the TOP of the starter. Other than that, it was a very easy install as I had the motor out for a tranny swap
![]() thanks for the input!
Definitely a different sound but as long as it starts the car I guess it's doing it's job. I'm glad this was posted as I have to do my car soon....I don't think the sound will make we not want the lighter weight hi-torque starter.
1989 911 Carrera 3.2, Guards Red |
Still here
The original starter takes almost a second to fire the engine compared to the high torque version which does it 3-4 times faster in my estimation. If the DME fires the engine after a fixed number of revolutions, that means a higher starting rpm. Not an issue on frequently driven cars, but could the quicker start have any effect on engine oiling and start up wear ? |
Should sound like a Chrysler product. They've used torque-reduction starters for quite awhile.
Sherwood |
