GTS GTS is offline
87 930 starting problems
Cold or warmed up, about 60% of the time having starting problems. Starts to fire and runs on what sounds like 2 cylinders. When you give it some gas is picks up to 4 cylinders for 5 to 10 seconds then hits on all 6. Once it is running, it runs great, but the start up is pretty embarrassing! Any DIY ideas???
Old 11-27-2002, 08:17 AM
the state of the tuneup, no cold start valve function, fuel pressure bleed-down due to leaking check valve, leaking injectors, a warm-up regulator starting out too lean, and various other things can cause that. do a search for "hot start", and see what comes up.
206 637 4071
Old 11-27-2002, 08:34 AM
