I need to replace the engine wiring harness on my '84 Carrera. Advice from the brain
Hi folks. The engine wiring harness on my '84 Carrera needs to be replaced. Mine's trashed (TRASHED!) where the cable and wires attach to the alternator. Melted and burned through. So, it's time to just replace the whole thing with a new one. However, I've looked all over this forum for hours for a thread detailing the removal and replacement of the harness, to no avail. Can anybody point me in the right direction, please? Hints, tips would be greatly appreciated from those in the know.
3.2 wiring harness
- the wrecking yards usually cut them so they can pull out the 2 "halves" - if that is a clue
have you priced that new one yet? p.s. - i have bought 2 of them used in the last 6 yrs - one (from FL wrecker) was cut "short" with the ends craftily taped back on to look like it was intact - no continuity end-to-end and the other (sold to me by a "reputable" Porsche independent shop in SoCal SF Valley) - said to be "refurbished" - the connectors on that one were also cut off & taped back on - but no continuity end-to-end neither was usable as purchased :mad: & it took me lots of hours to make 'em right, which included having to hunt down several of the special Bosch connectors - not regular shelf items, so that meant looking for old VW & Mercedes pieces at pik'n'pull |
I believe Timmy2 (on Pelican) makes some.
powellgillam@hotmail.com |
I removed my harness from my 77 project. I ended up cutting it so I could keep the fuse block attached. Took tons of pics before cutting it.
Timmy2 can make you one. http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/740894-building-sc-mid-year-engine-harnesses.html See this thread here too. Some outfit in Europe is making custom harnesses. http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/866864-wire-harnesses-930-turbo.html |
Yep. He does. I've already contacted him to build a new one. He does outstanding work. I've simply not wanted to bug him about R&R at this point.
I'm not afraid of tough jobs. I just want to make sure I do it right. |
Tdw28210, can you direct me to your thread?
http://forums.pelicanparts.com/porsche-911-technical-forum/779350-76-engine-harness.html |
DME wire harness removal........
Knot, If you want to remove the whole DME wire harness without cutting the wires, you have to pull them back inside the cabin. Look for the rubber grommet by the firewall (inside cabin) and pry it out. Disconnect all connections from the engine and carefully pull the harness towards the cabin. Installation is the opposite of how you took the DME harness out. Try to save the old DME harness and might find some use for it. You need to disconnect the main wire connector from the DME box under the driver seat. Tony |
Ah wel...
I totally get it. |
| All times are GMT -8. The time now is 07:47 AM. |
