7JX15 on 1973 911T?
Hi, I'm trying to figure out if I can put 7JX15 on the rear on my all stock/factory 1973 911T.
With out doing any modification?
If so what size tires will I need to avoid any tire rubbing.
I know this has been asked before but, on every forum I found threads saying you cant ,unless you change camber or add flares and some saying they did it with out any mods and no tire rubbing.
Thanks for your help
Old 11-03-2015, 11:03 AM
IROC's Avatar
The short answer is that "it depends". Each car is a little different and what works for one person might not work for another. I ran 7x15s with 225/50-15s in the rear with no rubbing, but I had 29 mm torsion bars and rolled fender lips.
Tire sizes are limited so you don't really have many options. I would suggest finding someone with a pair of 7x15s (and a 205/50 or 225/50 tire) and test-fitting them. It's really the only way to be sure.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 11-03-2015, 12:31 PM
Thanks for your help, I guess I'm going to have to risk it and buy the wheels and do a test fit with yoko 205/50/15.
Old 11-03-2015, 01:34 PM
Bill Verburg's Avatar
The bottom line is to keep the tires as short as possible, 205/50 are pretty short and ought to work
Bill Verburg
Old 11-03-2015, 02:01 PM
SweetE's Avatar
I thought Yoko only made a 205X55X15 tire??
Old 11-03-2015, 03:20 PM
Send a message via Skype™ to Porboynz
I have 205/60 15's on 7 inch Fuchs, no issues. 205/50 profile is too low for the street imo, fine for the track.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 11-03-2015, 11:24 PM
IROC's Avatar
I completely forgot about 205/60s! I ran those originally before going to the 225/50s. The 205/60 fits great. IMHO, that is the best compromise between width and diameter. I ran those before the torsion bar upgrade and they did not require rolling the fender lips. On my car, anyway.
Mike
1976 Euro 911
Old 11-04-2015, 03:57 AM
Bandwidth AbUser
Jim Richards's Avatar
This is from a post of mine in 2004. It pertains to my 1973 911E that I had back then.
Originally Posted by Jim Richards View Post
I can barely fit 225/50/15 on 7's without rolling the rear fender lips. I'm able to do this with Toyo T1-S tires, but not with Toyo's RA-1s. The RA-1 shoulder is a bit more squared off and this makes them hard to fit. I don't know what my camber is at the moment, and I might possibly be able to increase it a bit to improve the fit. BTW, my rear t-bars are 26mm (for now!).
Jim R.
Old 11-04-2015, 03:59 AM
irl irl is offline
irl's Avatar
Send a message via AIM to irl
195 60 15. Stock set up/lowered/no fender roll. 7T
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 11-04-2015, 04:47 AM
