Replace Fornt Indicator
Hi Guys,
I bought a new left front Turn Signal Assembly and a new Side Marker Light (911 G type - 1974). Is there a good technique or does anyone know the process of how to remove the old part and replace it? It seems to be not easy because the fixture has rust :( Thank you so much! Denis |
You don't specify whether your car is a Euro car or not. I presume your car is US and therefore that the turn signal and side marker lights are next to each other mounted to the bumper.
Assuming I'm correct, and assuming that nothing major changed between 1974 and 1987 (the year my car is), the easiest way to remove these is to remove the bumper. Here is a tutorial on how to remove the bumper: http://forums.pelicanparts.com/porsche-911-technical-forum/545165-88-911-bumper-removal.html |
Thank you wrxnofx !
| All times are GMT -8. The time now is 07:52 AM. |
