1974 Targa
Replace Fornt Indicator
Hi Guys,
I bought a new left front Turn Signal Assembly and a new Side Marker Light (911 G type - 1974).
Is there a good technique or does anyone know the process of how to remove the old part and replace it? It seems to be not easy because the fixture has rust
Thank you so much!
Denis
Old 11-04-2015, 03:14 PM
wrxnofx's Avatar
You don't specify whether your car is a Euro car or not. I presume your car is US and therefore that the turn signal and side marker lights are next to each other mounted to the bumper.
Assuming I'm correct, and assuming that nothing major changed between 1974 and 1987 (the year my car is), the easiest way to remove these is to remove the bumper.
Here is a tutorial on how to remove the bumper:
'88 911 Bumper Removal
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 11-04-2015, 04:14 PM
1974 Targa
Thank you wrxnofx !
Old 11-06-2015, 01:40 PM
Tags
side marker lights , turn signal assembly
