universeman's Avatar
Austin SC Targa owners please PM me?
I am trying to find another SC here in Austin to try my Dan Petchel top on. He says it should fit and that I should try other targas.
I did try jbunda's car but his is a Carerra and has roller latches, so I can't latch it down.
If you're in ATX and would be willing to let me try my top on your car, please let me know via comment or PM! As a bonus, you'll get to see Dan's work up close and test fit a new top for your car!
Thanks in advance
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 11-04-2015, 04:12 PM
1980 911 SC Targa
Jason, i too have a new Dan top. I had problems installing my top at first. Discovered what the problem was and it fits perfect now. Share with me what issue you are having.
Joe
Joe
1980 911 SC Targa
1998 911 Carrera S. Sold
1964 356 Sold
1983 944 track car. Sold
Old 11-04-2015, 04:57 PM
frankc's Avatar
I have a '77 Targa that you can try it on - should be identical to an SC, methinks. I'll PM.
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 11-04-2015, 06:17 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Post a pic brother.
'85 Carrera Targa
PCA/POC
Old 11-04-2015, 07:10 PM
Frank thanks - I'll find a time we can meet.
Joe/DRACO - problem is it doesn't reach all the way to the roll bar, and water gets in when it rains (lots of it.)
I've adjusted the heck out of it. Want to be sure my car isn't the goofy part because I've followed all Dan's advice...
Jason - Austin, TX
92 968 coupe
Old 11-04-2015, 08:00 PM
1980 911 SC Targa
My problem was the opposite of yours. My top was so tight it was difficult to re-install. Solution was to roll rear bead "up" before and during install
I wish you the best and hope you find a solution. Please post what you find
Joe
Joe
1980 911 SC Targa
1964 356 Sold
Old 11-05-2015, 03:47 AM
DRACO A5OG's Avatar
Let's post some measurements.
My top is 30.5" from center of it measured to the back of it on the car.
Sorry to ask but do you happen to know if the car has been in an accident or if you are using a Targa body brace? If a Brace, is the tension being pulled or pushed?
'85 Carrera Targa
PCA/POC
Old 11-05-2015, 09:44 AM
Weird, these cars tend to close up as they age, not open. Dan did my top and it popped right in.
He uses a jig to restore them so I don't think it is the top being dimensionally wrong.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 11-05-2015, 10:52 AM
Joe
flat6s-
What do you mean by "roll rear bead up"? I am having a similar issue. I just replaced my front seal (with Dan's) and targa bar seal and now it is a real bear to re-install.
Old 11-05-2015, 01:35 PM
Don't know if the car was in an accident but looks very clean underneath, bumpers seem original, no welds on frame, spot welds in hood are intact, etc.
I'm away from the car but will post measurements here when I can. You measured the front of the top bead to the rear bead, or the front bead to the roll bar itself?
Jason - Austin, TX
92 968 coupe
Old 11-05-2015, 02:12 PM
My top is also 30.5 and the opening measured from behind front and rear seals is the same, give or take an eighth.
1991 C2 Turbo
Old 11-05-2015, 02:24 PM
1980 911 SC Targa
Targe Tony
Pm sent
Joe
Joe
1980 911 SC Targa
1964 356 Sold
Old 11-06-2015, 04:22 AM
