occasional chain rattle
Hello to all ..i have an 84 3.2 carrera and every once in awhile after a long drive usually interstate cruising i'll park my car for a few hours and start it up and hear chain rattle...i'll turn the car off and let it sit for a minute or so and start it up again and the rattle will be gone.I'm sure it's cam chain rattle and It doesn't happen often.Anybody experience this.Thanks for the replies in advance.
Jay
Old 11-09-2015, 03:30 AM
If you're loosing a tensioner (Carrera) the rattle will be there until around 2000 rpms. They don't collapse enough to permit jumping time but need to be replaced.
To replace, you need to remove muffler, air channel, rear sheet metal after you lower the engine.
On the right side you lol need to remove the A/C console for room.
You'll need a chain box cover gasket and a cat to muffler gasket and a new tensioner.
If you're doing the right side, I suggest changing the cam oil line as while you're there..
Bruce
Old 11-09-2015, 04:20 AM
ok thank you for the info
Jay
Old 11-09-2015, 07:46 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Which brand and weight of oil are you using?
I had chain noise on occasion, switched oil per my wrench recommendation and never heard it since.
'85 Carrera Targa
PCA/POC
Old 11-09-2015, 08:07 AM
Draco i'm running valvoline vr1 20 -50W...seems like a popular brand for these engines
Old 11-09-2015, 04:26 PM
DRACO A5OG's Avatar
Hmm, that is what I am using currently. If I may suggest, try to start the car without the fan belt on to make certain it is the tensioner. Only for couple of minutes, no longer.
'85 Carrera Targa
PCA/POC
Old 11-09-2015, 04:28 PM
i/ve done that before trying to isolate the problem...guess the tensioners need to be replaced...just unusual that it does it every once in awhile and seems to come and go
Old 11-09-2015, 04:44 PM
DRACO A5OG's Avatar
Ah Man, that sucks. Please keep us posted.
'85 Carrera Targa
PCA/POC
Old 11-09-2015, 05:10 PM
will do...thanks for the input!
Old 11-09-2015, 05:50 PM
here's the required pic of my baby
Old 11-09-2015, 05:58 PM
DRACO A5OG's Avatar
Hmm Purty
'85 Carrera Targa
PCA/POC
Old 11-09-2015, 06:23 PM
