little smoke on start-ups
want to try an oil additive might help reduce smoke on startups - (it's #6 cylinder per having seen plug some time ago..) ;got some "Bardahl NoSmoke + Stop Leak" that sounds tempting - any comments as to possible effectiveness or issues from giving this stuff a try would be appreciated....'86 carrera cab with 68500, using Mobil 1 20W50. thanks
Dave
'86 944 '86 911 07 cayman |
Vafri
What color is the smoke? A little white smoke that stops after a few seconds is normal.
RETIRED
Just killing 'skeeters....fuggetaboutit...
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
no, it's an oil smoke. only when having sat at least a full day or two. wish it was just a puff of condensation... have heard let it idle a minute before shutting off to reduce this occurrence but that really does not seem to work... rather kill them skeeters with my headlights..
RETIRED
Typical dry sump engine start up.....
ok guy - maybe I am worrying too much about it. has pretty much done it since I got it about 6 thousand miles/3 years ago. was hoping to see if anyone had tried a similar product with any positive results.
Member 911 Anonymous
Try this.
Next time you come back from a drive of 30 minutes or more. Pull in, place the eBrake and let her idle for 1 minute before shut down. Do not blip the throttle. Make sure the level on the dip stick does not go over 1/2 way mark when hot. I found this will reduce the ploom to almost nothing. Strangely, when I am in a hurry and forget to let her idle for minute, the next day I get a ploom of smoke .Oh yah, don't sweat it. The joy of an older car
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
thnx all, feeling a little better..next dry day she's going for good run.
I did what Draco suggested on my old 86 3.2, it helped quite a bit. Tim
Banned but not out, yet..
Add one of these, which can be done with minimal skill and it will greatly reduce the problem. A little spendy but a quality product. Welcome to Rothsport Racing - Engine Products
And for gawk sakes don't dare install it backwards.
An air cooled refrigerator. ‘Mein Teil’ Last edited by RSBob; 11-12-2015 at 08:34 PM.. |
Totally normal . When you shut off the engine the oil drains into the bottom of the engine and coats the cylinder walls slightly. I just finished another engine rebuild and it smokes for about 30 seconds on start up as all the others I've done.
