zl0ca's Avatar
Engine/Transmission Mounts
What are people most commonly running on SCs? 99% is street use
Thank you
Old 11-04-2015, 06:17 PM
Porsche OEM mounts.......
Buy the Porsche OEM engine/transmission mounts. They are more than sufficient for your needs unless you want to go overboard and get those fancy aftermarket products.
Tony
Old 11-04-2015, 06:30 PM
Oh Haha's Avatar
Get the "sport" mounts as they will be a little stiffer than the stock versions. I had them on my SC.
The transmission and engine mounts are the same item, by the way.
Pacific Blue
Wayne
Old 11-04-2015, 06:39 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Go Sport ( cabriolet ) on Gear Box and Stock style on Motor.
'85 Carrera Targa
PCA/POC
Old 11-04-2015, 07:08 PM
El Duderino
tirwin's Avatar
+1 for the sport mounts. They are an inexpensive alternative to the aftermarket ones and provide extra stiffness over the original mounts used on coupes and targas. Using them further improved my shifting smoothness.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 11-04-2015, 07:53 PM
carrerarsr65
wevo on the engine ,blue pillow,porsche cab. style for trnny.
Old 11-04-2015, 07:55 PM
OsoMoore's Avatar
I got the German-made sport mounts from our host. I daily-drive on the so-so roads of Milwaukee, and they have been fine for me.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 11-05-2015, 07:49 AM
zl0ca's Avatar
Thanks. How much stiffer are the wevos over cabby mounts ?
Old 11-05-2015, 05:03 PM
83 911SC Cab
Cherry Bomb's Avatar
I went from tired, read broken, factory mounts in my SCab to Rebel Racing Blue's and now going back to factory new Cab/Sport mounts. No reason other than I have my SC down to a bare tub for complete suspension/gasket/preservation/rebuild.
I went with ER rubber for all suspension bushings and figured the engine/trans should follow suit.
The Rebel mounts were stout and the engine/trans were well planted. Some NVH at certain RPM's. Sweet mounts.
Cab/Sport mounts should be a bit softer than Wevo's or Rebel's softest.
Old 11-05-2015, 05:12 PM
El Duderino
tirwin's Avatar
Wevos are the stiffest as they are solid (or are they semi-solid?). I looked into this a while back. As I recall, the order is (from least to most stiff):
- OEM coupe/targa
- OEM sport
- Rebel black
- Rebel blue
- Wevo
Old 11-05-2015, 06:22 PM
zl0ca's Avatar
- OEM coupe/targa
- OEM sport
- Rebel black
- Rebel blue
- Wevo
Ok thanks for that line up. Little stiffer is ok but I'm not trying to lose a filling
Old 11-23-2015, 03:23 AM
I just recently installed the wevo mounts for both engine and trans. The ride is a little bumpier, but not uncomfortable. It was lowered to euro height at the same time, so maybe that's part of the change as well.
1986 911 3.2 Cabriolet
"We all have a desire to create something that will show we were here. " Ferry Porsche
Old 11-24-2015, 07:04 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Rebel blues. Solid ten out of ten, love them!
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 11-24-2015, 08:46 PM
