Radio delete panel fitment issue
Bought this here on our host's site, it doesnt fit flush within the recessed area like I imagined it would when I purchased it. Also is loose and tends to shift downwards on one side when driving. Anyone make a panel that fit's the hole properly and is recessed instead of sitting atop the surround loosely?http://forums.pelicanparts.com/uploa...1447224758.jpg
I used a dremal and made it fit the inside edging, and drilled two holes in the tabs and cable tied it in from the back.
http://i237.photobucket.com/albums/f...psl3dmjxvf.png |
es is right....a little time with sandpaper on a flat surface, and slight radius on the corners, to get the panel to fit the opening.
For a tighter fit, I used heat on the tabs to bend them to be a little more aggressive in their grip of the dash cut-out. pd |
| All times are GMT -8. The time now is 08:46 PM. |
