awdbandito's Avatar
Gaskets for Weber carbs to intake man.
I'm trying to figure out which gaskets I need that go between Weber IDA carbs and the intake runners. It looks like there are 6 gaskets total.
This is on a 2.7L with 40mm webers.
I see several different parts in the parts list and want to make sure I order the correct part.
Thanks,
'12 Cayman R
77 C3, 85 Carrera, 75 911S, 88 Carrera, 96 Carrera, '65 912, '06 Cayman S - Gone
Old 12-03-2012, 07:33 AM
KTL KTL is online now
Schleprock
KTL's Avatar
I'd think you need the second one on the list
Porsche 911 Intake System - Page 2
These gaskets are somewhat "standard" regardless of carb size. Here's another reference to prove that. Not trying to take away business from Pelican. Just pointing out that a Weber parts supplier (PMO, which is the same place Pelican gets a lot of their stuff) offers only one gasket size as well
Base Gaskets
Kevin L
'86 Carrera "Larry"
Old 12-03-2012, 08:09 AM
Kevin is correct, and I'd add that you need an insulator kit if you don't already have one. This goes between the manifolds and the heads.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-03-2012, 08:26 AM
awdbandito's Avatar
Steve, I believe I have insulators.
They are black and about a half inch thick and go between the head and manifolds.
I have been chasing a problem of backfiring and some spitting back up through the carbs.
I got the backfiring issue resolved by replacing all of my exhaust gaskets but am still spitting through the carbs.
I pulled the carbs and the gaskets that were used beteween the carb/manifold are home cut, and in some cases were doubled up. I am hoping this might be part of my problem.
'12 Cayman R
Old 12-03-2012, 09:22 AM
Vin-barrett's Avatar
I have Webers on my SC and looking for the gaskets above and below the PMO insulators. Still not sure I'm looking at the correct one
Is the part # 901-108-391-04?
Is it qty 12 of the same gasket?
Thanks for the help
-Vinny
1983 911SC
Old 11-12-2015, 11:14 AM
wayner's Avatar
subscribed
SOLD - 914 wide body hot rod
Old 11-12-2015, 12:38 PM
bavaria911's Avatar
Here are the insulators I used with fresh gaskets on both sides?
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 11-12-2015, 04:55 PM
Not as it seems
juanbenae's Avatar
ive got a whole set of carb gaskets laying around if anyone is in need. if interested email me and I can dig them out and photograph what I have and make an offer. it's all for sale!! like body & manifold stuff, nothing for the intakes.
Old 11-12-2015, 05:09 PM
