deathpunk dan's Avatar
Do Webers work well on an otherwise stock 2.4T CIS engine?
Hello
I have a line on a fully rebuilt 73.5 2.4T longblock. It has been completely rebuilt, top and bottom. Will this engine as presently configured play nicely with Weber carbs, assuming they are properly jetted? I have heard conflicting opinions on this. I realize this is a low (sub 8:1 IIRC) compression, super mild cam etc but I am looking for durability and good street manners, not a fire breather.
Thank You
Dan
Sepia brown 1971 911T.
Old 11-11-2015, 06:57 PM
1QuickS's Avatar
Cost may be a consideration along with convenience. Better to install new PMO carb kit than piece together used Webers, intake manifolds, linkage, air cleaners, and then have Webers rebuilt & jetted for your application. You will also need to have your distributor reworked to have an advance curve matched for use with carbs.
When in good condition and properly tuned, either Webers or PMO carbs will make the engine & you happy.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 11-11-2015, 08:04 PM
Vintage Owner
Jack Stands's Avatar
If you have the stock CIS system parts, another option may be to consider the Bitz Racing EFI conversion. It uses a Megasquirt brain to update the engine to a more modern fuel injection system.
I love my Webers, but do appreciate the drivability of the modern EFI systems.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 11-11-2015, 09:03 PM
Thanks guys.
I do have a set of Webers I rebuilt some years ago but never used.
After getting the COA and determining neither engine I currently have is orig to the car (one is a blank replacement case), I am evaluating my options...
Old 11-12-2015, 03:07 AM
Friend of mine has a 2.4T engine with carbs. Don't think it was a cis engine. With the help and some rework of the carbs by Paul Abbott he has one sweet running 2.4T. Paul is the master of the weber carb. He can give you advice for carbs on a cis engine. Personally, I really like carbs. Great looks and sounds and instant throttle response. Better access to the top of the engine.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 11-12-2015, 04:26 AM
T77911S's Avatar
my brother had a 2.4 with zeniths. i think that car was quicker than my 77 2.7. very quick and responsive. his was stock
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-12-2015, 04:36 AM
