Vintage Owner
Jack Stands's Avatar
Renewing black trim
I removed the vent window assemblies on my Targa to renew the window seal/stop and wanted to refresh the finish. Will simple black trim paint be enough or should I search out powder coating? Seems like some satin black rattle can paint should do the job as it's not a concours car.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 11-17-2015, 11:52 AM
Member 911 Anonymous
DRACO A5OG's Avatar
The paint will not hold up. At a minimum bake it but it will still wear off/chip off. If you can have it powder coated, you will be much happier in the long run. Might as well do all you black metal trim i.e. door handles
'85 Carrera Targa
PCA/POC
Old 11-17-2015, 11:57 AM
scarceller's Avatar
Paint can work, the trick is sand it down to bare metal then apply a good self etching primer, the self etch primer is the trick. Then top coat with paint. You'd be amazed how well paint holds to metal with self etch primer. Find a high quality self etch primer, try 3M products. The real good self etch comes as a 2 part primer, you can also find spray cans but the best is the 2 part.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 11-17-2015, 01:41 PM
universeman's Avatar
SEM Self Etching Primer and Wurth Satin Black is what I used. 1 year later (only) but it's holding up great so far.
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 11-17-2015, 04:53 PM
DRACO A5OG's Avatar
Yeah, I think that is what I did wrong, used wrong primer, thinking primer is primer. Just learned something
'85 Carrera Targa
PCA/POC
Old 11-17-2015, 06:23 PM
Non Compos Mentis
I used Krylon satin black rattle cans, and was very pleased. Proper prep is the key.
Old 11-17-2015, 09:29 PM
