83 SC won't start
My '83 911 SC hasn't been started in 16 months while undergoing a new paint job. I tried to start it today with not luck. Motor turns over but will not fire. Will start on starter fluid for a few seconds. I assume poor fuel delivery. Fuel pump working fine. Good fuel pressure at fuel filter. I disconnected the fuel delivery to the WUR and the car starts and runs well. Reconnect the WUR and no start. I have removed the WUR, cleaned it, cleaned the lines to and from and replaced the vacuum hose. Still no start. Please help. Car ran fine when I parked it. Even put fuel stabilizer in it.
Old 11-15-2015, 06:44 PM
Fleabit peanut monkey
Bob Kontak's Avatar
You may have a return restriction to the fuel tank.
1981 911SC Targa
Old 11-15-2015, 07:01 PM
Disconnected fuel line........
Andrew,
So what did you do with the disconnected fuel line to the WUR? You left it open or plugged it? And you ran the engine with a disconnected fuel pressure line? Hope you know what you are doing. Good luck.
Tony
Old 11-15-2015, 08:07 PM
