Brakes bleeding pressure at idle
So, my brakes have been acting up lately. I have normal brake pressure when driving, stopping, etc, no apparent change there. But, when sitting at a light, my pedal starts to drop over 15, 20 seconds until I hit the floor. If I keep my foot steady, I lose braking and the car will start to roll. I can pump the pedal once and it goes back to full pressure, then starts to drop again. I can repeat this forever, but I've started using the e-brake at lights instead. I know that it's not something mechanical in the pedal linkage, I installed a very sensitive mechanical brake switch, and the brake lights remain lit when the pedal drops away, so it's not a piece of linkage bending or anything.
I am running a custom Bitz setup, so the vacuum is not stock, and I do NOT have the venturi in place (it's been gone for 3 years, never noticed a difference).
Hawk HKS pads, Zimmerman rotors, ATE blue, all changed 16 months ago. Steel braided lines changed out, oh, 7 years ago? New caliper piston seals installed 7 years ago. Daily driver.
Any ideas? Blown master cylinder? Just worn out fluid?
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 11-17-2015, 10:25 AM
If you're not losing fluid, I'd say it's a master cylinder problem
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 11-17-2015, 10:27 AM
As far as I can tell I'm not losing any fluid. It's been this way now for 2, maybe 3 weeks.
Mike Bradshaw
Old 11-17-2015, 10:28 AM
Well, searching (I know, shoulda done that first...) shows this is normal for worn M/Cs.
Yuck.
Between never researching upgrades, and John Walker's warnings about poorly built ATE replacements, and always being temped to get something bigger now in case I go with bigger brakes later...
Yuck.
Mike Bradshaw
Old 11-17-2015, 10:46 AM
Member 911 Anonymous
DRACO A5OG's Avatar
When you bled te brakes did you inadvertantly drop the pedal to the floor while pumping? If so that most likely cause the seals to get damaged.
Just make sure you bench bleed the new MC before install. it is messy so be prepared. while you have her apart, inspect the booster too for a leak
'85 Carrera Targa
PCA/POC
Old 11-17-2015, 11:40 AM
I didn't change the fluid before this happened, but last time (14, 15 months ago) I used a Motive bleeder, no pumping.
I've done MCs before, and seem the damage that happens when you score the bore from over extending the piston.
Mike Bradshaw
Old 11-17-2015, 12:27 PM
Primary master cylinder cup isn't sealing. Remove, disassemble and replace or replace the MC. Do not bleed by depressing brake pedal to floor.
Sherwood
Old 11-17-2015, 03:09 PM
