Shifter slight move replace engine mounts?
Sport mounts on my 84 are about 4 years old. They've gone through 4 engine removal. I am now noticing slight shifter move (about 1/4 inch) when on off the gas. Is this an indication of mounts going?
Most likely the shifter assembly bushing/s.
End play of the transmission shafts will do that.
Mainshaft and pinion shaft, held in position by 4 point ball bearings which are held tight against the differential housing by retaining plates. The plates and bearings both can wear enough to allow some end play in the shafts. Being that the shift forks are in the shift sleeves, which are on the shafts, the movement is noticed in the shifter.
Update: no play this time after getting the car back from the shop. Must have been an adjustment issue as they've had to rr the drivetrain. Fyi tranny was just refreshed and my shifter bushings are pretty recent. Thank you John and Draco.
| All times are GMT -8. The time now is 12:41 AM. |
