wannabee wannabee
Shifter slight move replace engine mounts?
Sport mounts on my 84 are about 4 years old. They've gone through 4 engine removal. I am now noticing slight shifter move (about 1/4 inch) when on off the gas. Is this an indication of mounts going?
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) |
Member 911 Anonymous
Most likely the shifter assembly bushing/s.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
End play of the transmission shafts will do that.
Mainshaft and pinion shaft, held in position by 4 point ball bearings which are held tight against the differential housing by retaining plates. The plates and bearings both can wear enough to allow some end play in the shafts. Being that the shift forks are in the shift sleeves, which are on the shafts, the movement is noticed in the shifter.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 11-18-2015 at 05:13 AM.. |
wannabee wannabee
Update: no play this time after getting the car back from the shop. Must have been an adjustment issue as they've had to rr the drivetrain. Fyi tranny was just refreshed and my shifter bushings are pretty recent. Thank you John and Draco.
What exactly did they do?
wannabee wannabee
Replace removed tranny replaced synchros dogteeth sliders. I assume when tranny went back in the shifter/coupler is a little off. Then I needed to return the car so this time the adjustment is fine. Theres still a small play but not as huge as before.
