-   -   Source for Gibbs Mega Penatrant? (http://forums.pelicanparts.com/porsche-911-technical-forum/891839-source-gibbs-mega-penatrant.html)
Jayboundless 11-20-2015 07:10 AM
Anyone know of a good source for this stuff that may be found locally? My FLAP doesn't seem to carry it.
cobra935o 11-26-2015 11:59 AM
Summit Racing...
LJ851 11-26-2015 05:37 PM
http://www.amazon.com/gp/product/B00AFJXIJQ/ref=s9_hps_bw_g469_i1
wdfifteen 11-26-2015 06:20 PM
I've got a whole case of something called Gibb's penetrant. I don't know if it's the same stuff. I can ship some to you, as I'll never use it all. I'll go out to the shop in the morning and check it. I'll post a picture.
Cajundaddy 11-26-2015 08:03 PM
Or mix your own. Acetone-ATF mixture is known to work as-good-or-better than any retail penetrating oil at about 1/100th the cost.
For all of you that are mechanically inclined..... Penetrating Oils Compared A study done by Machinist's Workshop magazine in their April 2007 issue looked at different penetrating oils to see which one did the best job of removing a rusted bolt by measuring the pounds of torque required to loosen the bolt once treated. If the study was scientifically accurate, it turns out a home brew works best! Here's the summary of the test results:
Penetrating oil .......... Average load
None ..................... 516 pounds
WD-40 .................... 238 pounds
PB Blaster ............... 214 pounds
Liquid Wrench ............ 127 pounds
Kano Kroil ............... 106 pounds
ATF-Acetone mix.............53 pounds
The Automatic Transmission fluid (ATF)-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note the "home brew" was better than any commercial product in this one particular test. A local machinist group mixed up a batch and all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price.
964TargaC2 11-26-2015 11:01 PM
Gibbs Brand Lubricant at GIBBSBRANDLUBRICANT.COM
jkuntze 11-27-2015 07:17 AM
penetrating oil
had great results kroil
