Jayboundless's Avatar
Source for Gibbs Mega Penatrant?
Anyone know of a good source for this stuff that may be found locally? My FLAP doesn't seem to carry it.
Jay B.
85' 911 - Black
69' 911 - Signal Orange
Old 11-20-2015, 07:10 AM
Summit Racing...
Old 11-26-2015, 11:59 AM
LJ851's Avatar
http://www.amazon.com/gp/product/B00AFJXIJQ/ref=s9_hps_bw_g469_i1
Old 11-26-2015, 05:37 PM
wdfifteen's Avatar
I've got a whole case of something called Gibb's penetrant. I don't know if it's the same stuff. I can ship some to you, as I'll never use it all. I'll go out to the shop in the morning and check it. I'll post a picture.
Old 11-26-2015, 06:20 PM
Cajundaddy's Avatar
Or mix your own. Acetone-ATF mixture is known to work as-good-or-better than any retail penetrating oil at about 1/100th the cost.
For all of you that are mechanically inclined..... Penetrating Oils Compared A study done by Machinist's Workshop magazine in their April 2007 issue looked at different penetrating oils to see which one did the best job of removing a rusted bolt by measuring the pounds of torque required to loosen the bolt once treated. If the study was scientifically accurate, it turns out a home brew works best! Here's the summary of the test results:
Penetrating oil .......... Average load
None ..................... 516 pounds
WD-40 .................... 238 pounds
PB Blaster ............... 214 pounds
Liquid Wrench ............ 127 pounds
Kano Kroil ............... 106 pounds
ATF-Acetone mix.............53 pounds
The Automatic Transmission fluid (ATF)-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note the "home brew" was better than any commercial product in this one particular test. A local machinist group mixed up a batch and all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price.
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 11-26-2015, 08:03 PM
964TargaC2's Avatar
Gibbs Brand Lubricant at GIBBSBRANDLUBRICANT.COM
I think that maybe I'm dreaming..
Old 11-26-2015, 11:01 PM
penetrating oil
had great results kroil
Old 11-27-2015, 07:17 AM
