Thanks |
People rarely get the valves too tight unless they use the wrong feeler gauge. Typically they are too loose if anything given the locknut pulls the foot away from the valve stem or they don't have the rocker on the cam base circle.
Your problem is not valve adjustment. You either have the plug wires installed incorrectly or screwed up the ignition in some way. Did you change the plugs? |
Swap in the old plugs and see if that fixes it. They can be no good right out if the box.
What brand and type of spark plugs did you use? |
NGK=No Good Kind
Was words of wisdom from a Old German Mechanic many moons ago :) |
The plugs I installed were Bosch , I'm starting to think something is up with the plugs also.. ? First thing in the morning, I'm going to re - install my old plugs.... And try that. All it takes is one faulty plug for it to run bad
Is there a way to verify if a spark plug is good straight out of the box
If you can slide the correct size feeler guage between the cam lobe, and rocker foot, then thats not your problem, its electrical i am 90% sure of that, spark plugs, distributor, plug leads etc.
A few items that may help you,
You say you changed plugs,the correct procedure is to check your valves first before removing plugs,here is why if you removed the plugs first,because it makes it easy to turn the engine over while checking valve clearance,but what can happen is while doing this carbon pieces can fall from the plugs or cylinder chamber and into the valves, so when checking clearance not getting correct spec. new plugs should be changed after.Also another source while threading your plugs in using the factory socket you always have to be careful not to crack the side enamel on any plugs, as that will also give you a bad miss. go to www.google .com-----put in the words,---how to check valve clearance on Porsche 911.-----our host Pelican has really info on there,regards. |
What kind of resistance readings, should I get when testing spark plug wires. The spark plug wires look original to the car.. car has 117,000 miles
Your right at this point its either the spark plug wires or I F$ck up the valve adjustment. I know its not the rotor and cap, I put back all the old spark plugs, and it still runs like crap. |
I have one of these and it is great to test spark at each cylinder.
maybe you can borrow one. |
I just changed my wires on my '85. All were 2.9-3.0 kohms.
Based on your description, I don't think your issue is valves. I think you cracked some plug wires internally when you pulled the wires to install new plugs or knocked a vacuum line off it's fitting. Just doesn't sound like a valve adjustment problem.
Im ready to take my car to a repair shop and get it going, and re-group and give it another try at a later date. |
| All times are GMT -8. The time now is 07:43 AM. |
