Motive Power Bleeder question
OK...decided to use the Power Bleeder as designed to bleed clutch system rather than continually adding a little fluid to reservoir...bleed...add little more...bleed, etc.
However here is my question (did search and read Motive instructions but still not clear) Exactly how "full" should the reservoir be when I attach the Power Bleeder (with a quart or so of brake fluid inside) to the reservoir? When I open the slave bleeder screw I assume the fluid will flow into the reservoir but will it fill it up or does the level stay the same...i'm confused a bit on this part.
Thanks,
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 11-22-2015, 10:07 AM
I use my Motiv dry. Fill the reservoir, pinch off the overflow hose, pressurize and bleed the slave. That system bleeds quickly, so you should not run low on fluid unless you go too long after the bubbles are gone. Put a short 7mm box end on the nipple and attach a long hose into a pan, then watch for the air bubbles to stop. Pedal up in the process.
206 637 4071
Old 11-22-2015, 11:05 AM
Thanks John, the problem I ran into is I'm not very good/fast at getting the bleeder screw tighten back up. I ended up letting air into the system since the fluid dropped below the "intake" hose. Maybe I just need to work a little faster!!! Or maybe I'm opening the bleeder screw too far? It seems like when it's opened a little more it moves trapped air faster but maybe thats just my imagination.
Buck
'88 Coupe, '87 Cab,
Old 11-22-2015, 11:10 AM
That Guy
Techno Duck's Avatar
As long as you have the overflow hose pinched or capped off on the reservoir as John noted the fluid level in the reservoir will remain the same as when you started as long as some amount of brake fluid remains in the Motive tank. Bleeding with the tank empty on the clutch system is a good idea, it does not take much to get the air out and will save you the trouble of cleaning up the excess brake fluid.
If you dont pinch off the overflow line or if the cap at the reservoir leaks it will fill up the master cylinder to the max and make a bit of a mess when you disconnect.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 11-22-2015, 11:13 AM
That Guy
You only need to crack the bleeder open just a little bit; just enough to see fluid moving in your clear hose connected to the bleeder. If you open it too far, often times it will look like you have a ton of air in the system but in reality you are actually sucking air in from around the bleeder threads.
Jon
Old 11-22-2015, 11:15 AM
I have a 7mm box end about 3 inches long that works great for that job. Just open it a bit until it bleeds the air and shut it off. Keep your hand up there on the wrench. The long hose keeps the fluid off your shirt.
206 637 4071
Old 11-22-2015, 11:41 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
Routing the hose upward (at least for a few inches) at the nipple will also help the air bubbles to flow away from the nipple (as well as making them more obvious).
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 11-22-2015, 12:43 PM
Diss Member
Quicksilver's Avatar
BTW - The best upgrade to the Motive that I have done is add a quarter turn ball valve to the hose so I can stop the pressure without having to release all the pressure from the bottle (or spray brake fluid all over).
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 11-23-2015, 01:04 AM
OffCamber00's Avatar
I added a quick disconnect between the hose and the MC cap to achieve the same thing. Also makes it easier to screw on the cap w/o kinking up the hose.
Mat P
1988 911 Carrera
Old 11-23-2015, 06:09 AM
Spiderman
Jesse16's Avatar
Wow, two nice upgrades to my motive which I've been using dry since the first time with fluid. I'll be hitting the hardware store for a few items this week. Thanks for sharing.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 11-23-2015, 06:31 AM
I like the idea of the ball valve.
Buck
'88 Coupe, '87 Cab,
Old 11-23-2015, 06:42 AM
Picture? I use mine dry on all my cars this is a great idea!
Old 11-23-2015, 06:46 AM
Another upgrade is to drill a hole in it and install a metal tire valve so you can pressurize with your compressor instead of the slow hand pump.
206 637 4071
Old 11-23-2015, 06:59 AM
Spiderman
Jesse16's Avatar
Can anyone guess the hose barb size/hose ID or should I just cut the hose myself and measure to be sure ? Looks like your basic 1/4" probably.
Old 11-23-2015, 07:17 AM
Spiderman
Jesse16's Avatar
Brain fade moment, don't cut the hose at all, just put valve where the male/female connection is now.
Old 11-23-2015, 07:40 AM
Diss Member
Here is a cheesy mobile upload. Pretty basic. Went to Lowes and got a ball valve and a disconnect.
A lazy man's cheating device! I like it!
(Headed to Ace Hardware anyway...)
Old 11-23-2015, 12:04 PM
