-   -   engine trouble after valve adjustment and timing chain (http://forums.pelicanparts.com/porsche-911-technical-forum/892702-engine-trouble-after-valve-adjustment-timing-chain.html)
ismoto 11-26-2015 09:03 AM
hey pelicans,
did a engine out valve adjustment and installed new timing chains (with a hydraulic chain tensioner upgrade), reinstalled the engine and its not running all that well .. lots of black smoke and the engine is dying after a few seconds ..
what to do? 911 SC engine
stlrj 11-26-2015 11:05 AM
I would reexamine the cam timing.
boyt911sc 11-26-2015 12:08 PM
Cam timing........
Originally Posted by ismoto (Post 8893136)
hey pelicans,
Ismoto,
You could not install new timing chains without disrupting the cam timing setting. The cam setting is so sensitive that a very slight movement of the cam or sprocket could cause irratic engine performance. As previously mentioned, check your cam timing.
Tony
mreid 11-26-2015 12:15 PM
As said above, cam timing must be reset.
DRACO A5OG 11-26-2015 12:30 PM
+4
ismoto 11-27-2015 12:29 AM
thanks guys ..
