Daily Porsche Driver
engine trouble after valve adjustment and timing chain
hey pelicans,
did a engine out valve adjustment and installed new timing chains (with a hydraulic chain tensioner upgrade), reinstalled the engine and its not running all that well .. lots of black smoke and the engine is dying after a few seconds ..
what to do? 911 SC engine
Old 11-26-2015, 09:03 AM
I would reexamine the cam timing.
Old 11-26-2015, 11:05 AM
Cam timing........
Originally Posted by ismoto View Post
hey pelicans,
Ismoto,
You could not install new timing chains without disrupting the cam timing setting. The cam setting is so sensitive that a very slight movement of the cam or sprocket could cause irratic engine performance. As previously mentioned, check your cam timing.
Tony
Old 11-26-2015, 12:08 PM
non-whiner
mreid's Avatar
As said above, cam timing must be reset.
"Too much is just enough."
Old 11-26-2015, 12:15 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+4
'85 Carrera Targa
PCA/POC
Old 11-26-2015, 12:30 PM
thanks guys ..
Old 11-27-2015, 12:29 AM
