Daily Porsche Driver
oxygene o2 lambda connector
hey pelicans,
while re-installing the engine, the oxygene sensor broke at the connector near the gas filter .. i thought i can wire it back together but found out, the thin black cable is a single one, the green one on the other side has two cables in it, one inside and the other around the insulation .. any idea on how to wire it together? thanks! |
El Duderino
Send a PM to user Louie85. He makes a replacement kit for the male end. The male side is connected to a shielded (inner/outer) wire that goes to the ECU.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
okay and other than that? how do I have to wire the cables together? anyone?
