H5 Headlight Question - 88 Carrera
Hey All: Just replaced my left front, now they don't match as the original on the right is slightly oxidized/milky. Trying to live with it, but it is hard... Option would be to purchase another kit ($350) or try to polish the older/existing lense? I tried the turtle wax product last night, are the lense polishing kits primarily for plastic lenses or glass too? Anybody had any luck with them?
Also, I notice the right side light does not have the horizontal aim screw in it, was it not included on right, or would it be missing? Thanks everybody in advance. Erik |
That cloudy film may be in the inside. Remove the headlight, pull the lamp out and pour isopropyl rubbing alcohol inside the lens. swirl it around and let it sit a few minutes. pour out the alcohol and let it dry. Re-install and it will look like new!
Member 911 Anonymous
+1 isopropyl
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
this thread has some good ideas -- Fogged Headlights -- wasn't aware that some of these headlights have dessicant that will need to be removed before adding the alcohol.
I used the rice and alcohol idea on some old foggy h4s I bought used and it worked wonders. If for some reason the rice isn't stubborn enough, you might consider alcohol and salt -- since salt doesn't dissolve in alcohol, its crystals might provide extra abrasion. |
I have found that denatured alcohol (available at Home Depot) works even better than isopropyl alcohol. YMMV
Maverick Region PCA, Fort Worth/Dallas area 1987 911 Coupe, Black M491 3.4 // Turbo-Look Registry # 1249 1977 911 Coupe, Metallic Sienna (I think!)/Lobster SOLD 1982 924 White, SOLD long ago 1966 912 Red, SOLD, totaled a week later by its new owner |
French Import
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
You can also use a paper towel moistened with Windex. Stuff it through the bulb opening (maybe have to use half of a towel), and wipe it around with a pickup tool such as this one: Sears.com
In mine the cloudiness was easily removed this way. Mark
1979 911SC Targa |
Dial 911
I have helped a few local guys remove the stain on their headlight glass. I used 1200 'wet/dry' 3M paper, then with my Makita polisher, I have used one of 3M's 'Perfect-It' to buff and polish and they have come out as new. I used a wool pad.
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci |
Diss Member
One of the reasons the lenses cloud up is atmospheric moisture isn't being dealt with. There is a little plastic box at the bottom of the light that contains a desiccant that has certainly been saturated with moisture for years.
The replacement (911-631-968-00) is about $30 which is kind of ridiculous but you can refresh the desiccant by splitting it open. Silica gel can be refreshed by putting it in the oven at 220° for 15-30 minutes but it is easy to get new silica gel by pulling it from the packaging that comes with new electronics (or other christmas present).
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
I used the alcohol and rice swirl trick inside, worked great.
