1986 Carrera relay cut off question
Hoping someone can help me identify the location of a specific relay in my '86 Carrera. When I take the keys out of the ignition and open my driver's side door, the power no longer cuts off (windows go up and down, radio still works, etc). This is a new phenomenon which began about 3 months ago but I can't correlate it back to any event or change in the car.
Edit: Should add that the issue I'm experiencing is that I typically encounter a dead battery these days. My assumption was that, if the relay was working properly, the kill function would preserve the charge in the battery.
Old 12-03-2015, 11:42 AM
Undocumented User
McLaren-TAG's Avatar
May be as simple as your door switch is not responding due to corrosion etc and the door looks as if you've not opened it, keeping power to the circuits you mentioned.
Do the interior light come on and go off when you open/close the door?
Welcome to the forum BTW.
Old 12-03-2015, 11:58 AM
I'd put money on the door switch. Mine is bad and does exactly what you are experiencing.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 12-03-2015, 12:02 PM
Thank you for the quick replies!
McLaren-TAG - the interior lights don't work at all. I got the car about 18 mos. ago and spent a few hours mucking with them ('lights' plural, for the interior roof and the engine compartment) but to no avail.
chrisbruck - I'll take a look and see if I can investigate this further. Is there a replacement part number?
Old 12-03-2015, 12:24 PM
ganun's Avatar
BTW the relay is behind the fuel / oil gage, try pull it and if things get normal clean or replace the door switches. With a flashlight you can see it and get to it from the trunk, says FENSTERHEBER.
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 12-03-2015, 12:34 PM
Alex973's Avatar
thank you guys, same problem I had. the door switch fixed the
problem. why are we having the same problems same time, and
same mid 80's 911
"IGNITION LEFT OF STEERING"
Alex
Old 12-03-2015, 03:34 PM
ganun's Avatar
100 dollar relay, .....i just pulled the relay, even though the switches were cleaned. Just in case...
One day I miss to notice the dome light is not on and then kill the battery.
Old 12-03-2015, 04:00 PM
If you wiggle the door switch while the door is open the interior lights should come on and the radio and windows will "quit" working... at least that's how mine is. For 3 yrs I thought the windows working after pulling the key out was a "feature", kinda like newer cars have to roll up after the ignition is off. Nope, just a flakey door jamb switch.
Old 12-03-2015, 06:07 PM
Okay, so I had some time this morning and poked around using the advice and tips. Playing with the door switch didn't get me the desired results. What *did* work was opening the driver's side door fully and completely. Typically I open the door just enough to slide out. But when I swing the door wide, the electronics stop working. Solved the problem for today! Would like to get to the root but, right now, I think I'll just go for a ride.
Thank you again for all of your help and input. If I do figure it out I will post an update.
Old 12-04-2015, 09:20 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Remove the door switch carefully and clean/lube it. It is not making a good contact.
I say careful because you may be twisting the wire inside, it is a ground wire and may snap off into the abiss
'85 Carrera Targa
PCA/POC
Old 12-04-2015, 09:30 AM
SilverWT's Avatar
Originally Posted by VA_Zach View Post
When I take the keys out of the ignition and open my driver's side door, the power no longer cuts off (windows go up and down,...
Guys, you maybe confusing the issues.
The windows operating with the ignition off and a door open is correct for a most, if not all, 3.2s. Bentley shows a change to the wiring for 1985, but my 1984 already has this feature. It is also explained on page 9 of my original handbook as follows "When a door is open the power windows can be operated even if the ignition key has been withdrawn"
Terminal 85B on the power window relay was connected to the door switch circuits with two brown/white wires (in earlier cars 85B was not connected to anything). So the windows operate with the ignition on, or with a door open and ignition off making it more convenient to close a forgotten open window as you get out the car. They should not work with the ignition off and the doors closed.
You obviously have an intermittent connection/earthing issue, but don't get distracted by trying to cure a "factory feature".
Good luck in finding a solution.
Mark
Old 12-05-2015, 04:37 AM
