-   -   Best process for removing the Carpet fuzz/glue from Interior (http://forums.pelicanparts.com/porsche-911-technical-forum/894091-best-process-removing-carpet-fuzz-glue-interior.html)
em78911 12-07-2015 12:47 PM
Hi Guys
I am in the process of cleaning the Interior up for to receive a coat of paint when the entire car gets painted.
I am going for the 964 RS/NGT Club Sport look for the interior.. what is the materials and process to strip the carpet fuzz and Glue from the inside? I have heard 3M adhesive remover is good.. what is the best way to use this to remove the glue? a scraper? or something else?
Thanks for any and all input on this process..
-Eric
cnielsen 12-07-2015 01:08 PM
Try white camping fuel. Works well to loosen adhesive.
geoz 12-07-2015 01:10 PM
I used adhesive remover. Worked well on the adhesive the factory used.
em78911 12-07-2015 01:20 PM
what methods did you use with the cleaner? a scraper? or a brush?
Mick_D 12-07-2015 01:51 PM
I used Goof Off Pro and a green kitchen scotchbrite, plus a razor blade or 3 and in a couple places, pieces of wood shaped to fit. It worked really well. You will use a lot of Goof Off though.
Goof Off Pro on Amazon
I painted the goof off on in about a 1-square foot are at a time. Let it si8t a few mionutes, then scotchbrited it ( I used 4 scotchbrite pads total) until the solvent was gone. If the area needed it I repeated, and if there were stubborn spots I used the razor blades/wood. The toughest areas to do were the rear seats.
gliding_serpent 12-07-2015 02:32 PM
Subscribing because I may end up doing a bit of this, although for the most part the original paint is good so I may just glue my new carpets on top.
Sebscst 12-07-2015 03:31 PM
Try citristrip and plastic scraper.
Busta Rib 12-07-2015 03:48 PM
+1. That stuff works miracles. Just spread, let it sit for a few hours, and then scrape.
This is an opportunistic plug as well. I bought some Citristrip to do the exact thing on my car in preparation to install an RS carpet kit but ended up taking my car to a shop and they did it for me so didn't need them. I have them for sale on Ebay: 1 Quart Citristrip Gel Stripper 5 Bottles | eBay
