em78911's Avatar
Best process for removing the Carpet fuzz/glue from Interior
Hi Guys
I am in the process of cleaning the Interior up for to receive a coat of paint when the entire car gets painted.
I am going for the 964 RS/NGT Club Sport look for the interior.. what is the materials and process to strip the carpet fuzz and Glue from the inside? I have heard 3M adhesive remover is good.. what is the best way to use this to remove the glue? a scraper? or something else?
Thanks for any and all input on this process..
-Eric
Old 12-07-2015, 12:47 PM
cnielsen's Avatar
Try white camping fuel. Works well to loosen adhesive.
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 12-07-2015, 01:08 PM
geoz's Avatar
I used adhesive remover. Worked well on the adhesive the factory used.
cheers
hg
1988 911 Cabrio
Old 12-07-2015, 01:10 PM
em78911's Avatar
what methods did you use with the cleaner? a scraper? or a brush?
Old 12-07-2015, 01:20 PM
Mick_D's Avatar
I used Goof Off Pro and a green kitchen scotchbrite, plus a razor blade or 3 and in a couple places, pieces of wood shaped to fit. It worked really well. You will use a lot of Goof Off though.
Goof Off Pro on Amazon
I painted the goof off on in about a 1-square foot are at a time. Let it si8t a few mionutes, then scotchbrited it ( I used 4 scotchbrite pads total) until the solvent was gone. If the area needed it I repeated, and if there were stubborn spots I used the razor blades/wood. The toughest areas to do were the rear seats.
Old 12-07-2015, 01:51 PM
gliding_serpent's Avatar
Subscribing because I may end up doing a bit of this, although for the most part the original paint is good so I may just glue my new carpets on top.
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 12-07-2015, 02:32 PM
Try citristrip and plastic scraper.
78 911 st backdate
87 944
00 996
Old 12-07-2015, 03:31 PM
GOM (Grumpy Old Man)
Busta Rib's Avatar
+1. That stuff works miracles. Just spread, let it sit for a few hours, and then scrape.
This is an opportunistic plug as well. I bought some Citristrip to do the exact thing on my car in preparation to install an RS carpet kit but ended up taking my car to a shop and they did it for me so didn't need them. I have them for sale on Ebay: 1 Quart Citristrip Gel Stripper 5 Bottles | eBay
Instagram: @3pedalposse
Old 12-07-2015, 03:48 PM
