lgowin's Avatar
Rear Wheel Rubbing Shock?
I've got an '88 with Elephant Racing suspension and I've noticed the rear wheels are slightly rubbing the shocks. This would have happened during Driver Events at High Plains Raceway. I marked the rubbing on the left side and it didn't seem to touch after I ran Pikes Peak International Raceway. Do my wheel bearings need to be tightened up a touch? Improperly torqued shock mounts?
BTW, I'm running 225 50 R16s in the rear.
I'm dropping the engine to do the clutch and want to sort this as well.
Regards,
Lawrence
Old 08-12-2021, 07:23 AM
Bill Verburg's Avatar
Regards,
Lawrence
Assuming you have stock 8x16ET10.6 Fuchs it's probably not the tire unless there is something very very wrong
that tire on the Fuch 8 has over 1 3/4" clearance from anything on the inside
Bill Verburg
Old 08-12-2021, 08:09 AM
Behind the Sun
Go to competent porsche shop with aligment in house.
Hopefully nothing is bent.
Hopefully no history of accidents
Old 08-12-2021, 08:22 AM
lgowin's Avatar
Thanks - good suggestion on the alignment. I had everything dialed in by a Porsche specialist with I fitted the Elephant components and they didn't note anything wrong. It's all very straight and has done a great job of running with the big kids at a couple driver events.
I'm getting ready to drop the engine for some maintenance. After I give the shocks a good tightening, I can take it back in for an alignment and see what the pros say.
Lawrence
Old 08-14-2021, 06:35 AM
