SCEET Aircraft duct
I'm buying all the components to finish my heat backdate project. Can somebody provide some insight of how much hose I actually need per side for the 3.0?
I plan on using the 2.5 inch ducting from: SCEET AIRCRAFT DUCTING - CUT TO LENGTH from Aircraft Spruce |
I documented it somewherre in my "beginning of the end" build thread. Should be in the first half.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
10' length will get you there with a little left over.
Be sure it doesn't have a red rubber liner or you'll smell it when it gets hot.
Undocumented User
It's really hard to search Pelican, far easier to just use Google. "lenght of sceet backdate" gets you this.
how much ducting for a 3.2 heat backdate? |
From my thread:
- heat backdate: Will include engine tin cut, repaint. Search : Tips & adivce needed for backdating heat. Ordered 72 inches of SCEET. (Job should require 60 inches - 24 + 18 + 9 + 9) This should give enough to allow rolling of the ends for better fit.
Thanks for providing me with an answer! |
JJ911sc shard it with me from his engine. You will see photos of it if you search around. Beautiful engine.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 12-26-2015 at 07:29 PM.. |
83 911 Production Cab #10
zl0ca Here is a good view of the path and the hoses length. IIRC the best deal from Spruce was the 10' length so you can sell the other 5'
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Thank you for the engine porn and of course hose path
What's wrong with the better looking 911 211 522 00?
JJ - the carbs look great. Did they go on recently? I remember you mentioning them the last we spoke.
John W... I think I overlooked those because I read on pelican that they were a bit more fragile. Sounds like you have no issue with them? I might try those if I need to get new hoses for new headers... I want a black and silver look for my engine if possible.
For the look, I went from the normal Rain Shield set-up to the Flat Top to Individual Flat Filter to Half Tea Ball Filter version. The versions pictures below "required the Can Catch" set-up. Race Top ![]() Flat Top Filter on Flute ![]() Half Tea Ball Filter on Flute [/QUOTE]
Now i think i remember, you had carbs but were thinking adding a supercharger right?
