What tools do I need for a brake flex line replacement project
I'm probably search-challenged, but I'm having a hard time finding a comprehensive list of tools that I will need to replace all four flexible brake lines on my '87 factory turbo look coupe. Could someone help a brother with a specific roll-call of what I will need? I have the hoses (ATE) on the way from our host, other than that, I'm at square one.
Many thanks, and happy holidays to all! Rob |
Flare wrenches.......
Rob, Determine the fitting size/s and use flare and box type wrenches. Avoid using open or adjustable wrenches as much as possible. Use heat as needed. Tony |
9/16 and 11/16 open end wrenches (14mm and 18mm in a pinch, but I found that 9/16 and 11/16 fit better).
11mm flare wrench. Flat blade screwdriver. 19mm socket and wrench for lug nuts. Jack and jack stands. brake cleaner and rags. That assumes that you do not remove the calipers. It's possible to do the work with them in place, but it's much harder to see what you're doing. If you are willing to remove the calipers, then they have 2 bolts each, 19mm socket (17mm socket? I think it's 19mm...) for the front and a 17 or 19mm box wrench for the back (and lots of swearing and busted knuckles and annoyance). 8mm socket or wrench for bleeder. |
You might find something here.
Porsche 911 (1965-1989) Technical Articles - Pelican Parts |
buy yourself an 11mm flare nut wrench..
The metal lines that connect from the caliper to the rubber line, are likely slightly corroded.. From experience, you CAN use a normal 11mm crescent wrench, but a proper flare wrench will grip it with much more positivity, and virtually eliminate the chance of rounding it or stripping it. If you do ruin the metal lines, then you will need to order replacements from your local Porsche dealer.. and they usually have to get them from Germany.... ask me how I know all this!! I just did this job on the weekend... |
Also, getting the spring clips off is fun... they retain the end of the rubber hose and stop is pulling through the mounting...Mine were corroded and gunky and took a LOT of persuading with a lever to get them off.
This article has all the info you should need. Pelican Technical Article: Brake Line Replacement - 911 (1965-89) - 930 Turbo (1975-89) |
If you can validate with an everyday 8mm wrench/socket, spring $20+ and buy a Snap On 8MM six point or $10 for a MAC six point box wrench.(Used on Ebay) You should be fine with a Craftsman quality six point socket. Just insurance. |
Seems to me that if you have to ask maybe you should take it to a shop, I just did my 87 and 3 of the four lines were rusted to the steel line, which means the hose has to be turned to unscrew from the steel line rather than the swivel fitting. A pita and if you don't realize you quickly twist off the tip of the steel line, another big pita. It all depends on the condition of the fittings, if you encounter frozen fittings, take it to a shop. My 2 cents. BTW see Why to change rubber brake hoses.
I tried maybe three different bleeding methods. Motive etc. When you finally get ALL the air out, it's wonderful. Like, "Oh, that's what they are talking about".:) |
Many thanks to all who responded! I did this little project on my '77 decades ago... wasn't too hard. Now, thanks to you good Pelicans, I know what I need and I can have all my tools n' stuff together and make quick work of it.
Thanks again!! Robhttp://forums.pelicanparts.com/uploa...1450823280.jpg |
vise grips
You dudes forgot to tell him to get a lug wrench for the wheels. You're slipping...
Ooooooooo...slap him.....slap him hard!!!
Rich, if I do that, then Bob will think that Santa got here early! |
Oh yeah...Santa's little helper! On Rudolph!!! On Prancer...
I do not play these strange sexual reference games. I don't think like that. FWIW, Here's Rich with his special mask thinking "Hell yes".............. http://forums.pelicanparts.com/uploa...1450834987.png |
PB Blaster applied 2 or 3 times a day or so before you begin...
boxwrenches, boxwrenches, boxwrenches. Also hit the connections with PB blaster first |
If you are DIY self type Porsche guy, you should have a full set of tools. Then you use what fits. If the DAPO rounded off the connections, the vise grip is the smartest fall back. As is PB blaster, a MAPP torch, cheater bar, sawzall and any other grunt, grunt device.
I also include band-aids, beer and a helper in case the car falls on you. The helper can also make a beer run whilst you scratch yer haid and do the WTF look. |
The 11mm flare wrench is the only specialty tool you will need.
The first time I changed mine it took me like five hours. The second time, I did it in about an hour, while having a conversation with a friend. Do NOT remove the calipers! Why would you want them to be moving around when you are trying to remove the lines? My calipers were off the second time, and then I had to re-align the hard lines when I mounted them back up. Not the end of the world, but a second step nonetheless. Just take your time, and have fun. |
Wow 32 posts for flex line replacement? I've seen less for transmission overhaul. Merry Christmas Pelicans great board, very helpful.
We had a 4 page thread a while ago about removing the steering wheel. No, really! It just kept going and going and going... |
Yeah, but can you do it without smashing yourself in the face?!
Nice job. |
I like it. Plus the jokes are better than Joe Bob's. |
Just doing my part to keep the brotherhood alive..
..and then pesky Pazuzu comes along and f's it all up. |
That whole 19MM socket thing, although he did mention it well before you beat our batch asses to death for not, is probably a point I will bring up with him.:D Seriously, happy holidays to all. |
Btw, either your advice to Obama sucks or he's not a good listener. Given its Christmas, I'll go with the later. Step it up in 2016, okay? We're all depending on you.
| All times are GMT -8. The time now is 07:25 PM. |
