-   -   Some concerns about strut mount re-installation (center nut) (http://forums.pelicanparts.com/porsche-911-technical-forum/896122-some-concerns-about-strut-mount-re-installation-center-nut.html)
BFT3.2 12-26-2015 07:02 PM
Im not sure if its the "right" official tool, but I used a motorcycle shock wrench similar to this one.
http://forums.pelicanparts.com/uploa...1451185341.jpg
javadog 12-27-2015 02:57 AM
Originally Posted by wrxnofx (Post 8932480)
What IS the correct tool to hold the large washer?
I don't know what the tool number is but it looks pretty much like a motorcycle shop tool. It's pictured in the factory manuals.
Just buy a motorcycle shop tool of the correct size. They are easy to find and cheap.
JR
sugarwood 12-27-2015 03:36 AM
I think the $20 moto shock tool is called "(universal) preload adjuster"
http://www.amazon.com/Pit-Posse-Motorcycle-Adjustment-Spanner/dp/B005SUYU8U
http://www.amazon.com/Motion-Pro-08-0029-Spanner-Wrench/dp/B000GZP270
I can easily envision this thing slipping out of the slot, just like a screwdriver.
javadog 12-27-2015 03:43 AM
Have somebody help you, then. One to hold the washer, one to tighten the nut.
JR
sugarwood 12-31-2015 01:17 PM
Channellocks worked to hold the washer in place while I torqued it down to 58lbs.
http://i68.tinypic.com/nn4rgz.jpg
I installed the new single bore mounting plates.
Thanks to BFT3.2 for giving me his spare cup washers.
http://i64.tinypic.com/24e48k4.jpg http://i68.tinypic.com/w86adj.jpg
I prefer the extra room...
http://i67.tinypic.com/2w3ypli.jpg
zl0ca 01-22-2016 06:14 PM
I removed my brace too. Can you tell me where you purchased the missing washer?
sugarwood 01-22-2016 07:07 PM
See post #2/ Pelican sells everything.
