-   -   Engine conversion help needed 3.2/901 (http://forums.pelicanparts.com/porsche-911-technical-forum/897040-engine-conversion-help-needed-3-2-901-a.html)
mepstein 01-02-2016 02:26 PM
I'd like to attach a 3.2 to a 901 trans. What clutch, flywheel and pressure plate do I need? Thanks, Mark
Part numbers if you have them.
Cairo94507 01-02-2016 02:43 PM
Hey Mark - Check with Scotty. He has all of my PMS parts to connect my 901 to the 3.2. Happy New Year. Michael
john walker's workshop 01-02-2016 05:29 PM
Good luck on longevity.
ClickClickBoom 01-02-2016 06:48 PM
But it will be magnificent in its, resultant demise.
Jack Stands 01-02-2016 08:27 PM
If you're easy on initial takeoff and don't use first gear, it may last for a bit. Same could be said for CV joints. There's a reason Porsche went with the 915 and then G50 gearboxes.
larrym 01-08-2016 08:34 PM
posted this before
3.2 901 clutch conversion parts "kit" larrym
- The clutch kit consists of these parts: – kit cost me $1050 in 2007 from GPR
Sachs 0251 410 31K 228mm disc,
KEP (Kennedy) Stage 1 Pressure Plate,
Porsche 901 102 033 01 Flywheel,
+ 130-tooth ring gear extension (no part no.)
Sachs 3151 132 132 T.O. brg,
(PP & disc are stock VW bus clutch items)
caveat - there is a variant 915 FW - uses a different T.O. brg (i have that FW/Clutch/TO packed away in a box - remnant of a project i gave up on) - you will see both in the Pelican catalog
i am running this setup - and so are lots of 914-er conversions - many threads on this, esp On 914World
p.s. - have PCA friend who ran a 350 chevy in a 914 scca race car with a 901- never killed the 901 - most cognoscenti i've consulted believe that the 901 will handle 250 hp if you treat 1st gently as suggested above - many threads on this, esp On 914World
- i never start in 1st at AX (but i do use 1st to get started up the hill of my driveway)
AND
(i have 2 good extra 901's if i ever somehow get stupid & forget during a red mist that i can't rev to 6000 & drop the clutch in 1st)
(and i have a 915 & Bott 916 kit on the shelf as well)
