Never said anything about eddy current loses. Eddy current loses result from the molecular structure of the core material and induced current flow in that material. The subject matter regards the amount of magnetic flux vs ampere turns. Example: 1 ampere turn with an "I" core transformer or inductor will be produce "N" levels of magnetic flux, whereas 1 ampere turn in an "E & I" core transformer or inductor will produce "N" * X levels. In the linked document X = 1.6 |
This is all very interesting but what is the answer to the ORIGINAL question?
Can I safely use a MSD Blaster coil? |
There is no data on any of them so it is just an opinion.
But what fun is that when you can rewrite scientific laws? |
I think when you get by all the dick swinging the answer is yes.
Discovered that cooling the CDI box, garden hose water spray, would result in the car starting back up right away. Your CDI box may be overheating, or the MSD blaster. The latter becomes more probable if you non-resistor wiring and/or sparkplugs. |
CDI coil values are indicated and linked to in post #29. Maybe helpful in choosing a replacement CDI coil. |
Page 48, figure 34, Bosch GT40 cannister coil, 17mj.
Page 49, figure 35, Bosch GT40T transformer "coil", 28mj http://forums.pelicanparts.com/uploa...1452626150.jpg |
| All times are GMT -8. The time now is 10:51 AM. |
