Is the MSD Blaster igntion coil compatible with the CDI unit in the 1973.5T 911?
My car has been known to suddenly die after a long run on the road and I thought it might be fuel related. Lately though someone suggested that the MSD Blaster ignition coil I installed might be overheating and causing the shutdown after a nice run with the car. The questions came up as to whether I was using a non-resistor rotor? does the Blaster has an internal resistor? or I have external ballast resistor?
I do use the 6500 rpm cut off rotor, which I just realized is not the "non resistor rotor". I will switch to the non resistor rotor, but can anyone shed any light on what's going on with this system set up. And yes, I have bought the silver made in Brazil coil, which failed me miserably after purchase. thanks Bob 1973.5T |
Bob,
I was searching for the same issue a few years back. I don't remember where I found it in this Forum, but there is a post from either Warren Hall or Grady Clay regarding the MSD master blaster coil. From the testing that he did, he determined that the coil was the exact same spec as the original factory coil. Not sure if that answers the question but hopefully can point you in the right direction. Matthew
Matthew - drove Nurburgring with wipers on and no rain 1969 911E SOLD ![]() 2002 996 Cabrio 1995 993 Carrera 4 SOLD 2004 Land Rover Discovery II G4 Edition (Sold )
dont know about your question. but during the build of my 951 DE/street car I installed a MSD blaster coil. it died on the first drive within minutes. replaced with another MSD and it died after a few months.
put the original coil back in for now, until I decide if I am going to go a full MDS / AL6 good luck.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
I wouldn't go near an e-core coil the specs are absolutely wrong.
Here is my compilation of coil data: A lucky eBay find: NOS SWB Coil
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Appreciate the data.
Bob 73.5T |
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Better.....
ProFire PFC-M75, CD Ignition I ran one of these for years with Bosch CDI and it was great. I still have it if anyone is interested in purchase. Switched to Daytona CD1 coil that came with kit.
![]() This is the NOLOGY COIL. The bracket fits right on the studs on the fan mount.
A picture says a thousand words...
Lets see how they look mounted...
Extremely Yellow ’74 Targa 2.7 L - aka WIFE’S BANE |
I care how they work. E coils have been great for me. the Nology coil was great with the stock ignition, the other Daytona coil matches my CDI and has been flawless.
John Walker would know. When I did the MSD and MS coil, we had to change the rotor.....He picked up a common one at a local FLAP store....I thought still had the box with the part number, but no cigar....
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
dicklague
Sent you a pm Ernie 81sc |
I can't give an absolute yes or no to the OPs question as I haven't personally tested an MSD coil.
The CDI box and coil, although separate parts, are part of the same circuit so they are matched at design time. If the coil is changed to a different type with different characteristics, this could result in excess heat being generated in either the coil or the box. In extreme cases, the CDI output circuitry could be destroyed. This is why most aftermarket ignitions require that you also use their coils. You need to compare the MSD and original Bosch coil specifications for primary resistance, inductance and number of turns. See whether they are in the same ballpark. |
In both cases the not unsubstantial energy left in the magnetic field post plug firing will be returned to the "charge" capacitor.
(page 43, "-100") "I" core: That 60% energy level loss due to magnetic field "leakage" will be dissipated as HEAT with in the coil structure. (Page 48) http://www.worldphaco.net/uploads/CAPACITIVE_DISCHARGE_IGNITION_vs_MAGNETIC_DISCHARG E_IGNITION..pdf Last edited by wwest; 01-11-2016 at 11:10 AM.. |
How, where...?? The primary components affecting the coil, or being effected by the coil, are reactive, very low circuit resistance to dissipate energy as heat. Plus moving from ANY "I" core coil to an "E & I" would obviously reduce spark energy loss substantially "..aftermarket... ignitions require..." Read: COILS http://www.msdignition.com/uploadedFiles/MSDIgnitioncom/Products/Ignitions/6420_instructions.pdf http://static.summitracing.com/global/images/instructions/sum-850610.pdf Last edited by wwest; 01-07-2016 at 05:10 PM.. |
^ Ok, feel free to stuff any old coil in there then. It doesn't matter what the designer of the circuit intended the CDI circuit to drive. A few turns of wire round an old shoe will do and is cheap and easy to make. Wire coat hangers make great ignition leads as well and you can insulate them with tape and chewing gum.
Remember, Porsche really didn't know what they were doing when they designed this stuff. It can all be replaced with homemade equipment or shoddy crap made in China and it will be absolutely fine! Trust me, I read it on the Internet! |
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Having trouble eating crow..?? Last edited by wwest; 01-08-2016 at 01:02 PM.. |
