Discussion on the Future of CDI Boxes
This thread: cdi-msd-done-thanks,was very informative, but got me thinking on what is the future of our 911s when it comes to electronics. I did not want to hijack his thread, so I started a separate one.
Most here are familiar with the red MSD CDI boxes. The referenced thread discussed the installation of a MSD Streefire. A good one, too. There are many other threads that discuss who to do it, and the modifications needed. Plus, he availability of reproduction plugs from Timmy2 makes the wiring that much easier. Plus there are some spectacular options for street & racing listed here for sale at Pelican Parts. Including the beautiful twin-plug distributors. There are multiple re-builders of the Bosch units available via Pelican Parts. Factory refurbished too. But now there is Classic Retrofit and their direct drop in, modern CDI. Per "911 & Porsche World" December 2015, pages 106-109, there is a great write up on Jonny Hart and Classic Retrofit. A lot of thought went into the cdi+ box. But, I have to think, as my 911 transitions from a track car to a truely historic car, and the value goes up, retaining a stock looking interior and hardware becomes more important. And the originality drives the value. The double edged sword of affordability and value; Can I afford a valuable car? Msd might be the near term solution, but I think perhaps the cdi+ will be one of the long term solutions as it will enhance the perceived originality. A MSD programmable costs $375. But a $150 streetfire does most of what I want. The Electromotive XDi makes sense too, especially for EFI conversions. But it is not even close to stock looking. The ~$1400 (995 pounds sterling) CDI+ does it all and is "stock" in all the critical aspects except internal modernness. It compares cost-wise very well with a factory refurbished CDI box, and frankly the newer electronic design and programability make it function better than NOS. Is $1400 now, a better investment, compared to $150 to $375 now (plus the cost/time of the required modifications), and then change to something else 6 years from now, when my SC turns 40 and I want to undo it all and go back to stock?
Mike '82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar. |
CDI+ is not the only game in town. ************ makes new fully modern CDI boxes and ignition transformers for significantly less than $1400. Their CDI box for your SC is about $800. I have their 3 pin box and transformer in the 70 and it works fine. Check it out.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
It is my belief that nearly all 911s can be made to run better with timing adjustments than when they were new. Why? Well, it is mostly down to fuel quality which is much better these days. Also, if you have changed anything on your engine (fuelling, cams, headers, exhaust) you are definitely missing a trick not having the timing setup on a dyno. I perhaps haven't made this clear but our cheaper 'basic' unit is exactly the same as the 'advanced' unit. Microprocessor accuracy with input delay compensation, hard, soft and launch rev limiters, tacho cal, shift light, dual spark etc. It just doesn't come with the diagnostic cable or software support. You can, however, still have a curve setup by an approved shop that has our kit. You can also have the diag cable fitted at a later date which makes the same as the 'advanced'. Click here for full technical manual It is our hope that once we have enough dyno feedback, we can ship our basic unit pre programmed with an optimum timing curve for your 911 dependent on engine spec. Oh, and yes, our unit is still half the price of an original unit from Porsche which are on six month back order last time I checked! Last edited by Jonny H; 01-03-2016 at 11:01 AM.. |
Dave |
On the other hand, I see a real opportunity...
A modern day implementation of the Kettering inductive ignition system to be housed in the factory CDI box, marketed as kit including ad E & I core transformer type coil. It's pretty obvious to me upon reading, and as a participant in, Jonny's post series, that the inductive system, using modern circuit design, will provide a much hotter, longer duration spark. So, Jonny, why not go back to the drawing board..?? Could an E & T core coil/transformer be designed having the factory coil "look"..?? |
The microprocessor compensates for this inaccuracy over the rev range which results in an accuracy better than 0.1 deg @ 10000 RPM. Quote:
2) Some timing curves are physically impossible to achieve. We had a highly strung race car that would not return to idle nicely. Mixture adjustment didn't help. The tuner put in a little sine wave dip just above idle and the issue was resolved. Quote:
Here you go, see the 'repair', just waiting for the next 40 year old component to fail: ![]() In this case the customer didn't want his Bosch case refurbed, so we left it warts and all:
I proposed a discussion on the future of 911 electronics as we move from daily drivers and low cost replacements to rare/valuable/collector cars and the higher cost but stock like equivalents. Not a technical attack on a particular manufacturer with whom you disagree with.
In response to a direct question: I made my statement on "function" vs NOS based on the ability to program a rev limiter and to tweak the advance curve. Two significant improvements (functions) not available in the stock box. IMHO that's a huge benefit that can be used in the real world. My reasoning: I'm currently running with a rotor rev limiter. It's a little bit of a wildcard as to when it really kicks in. I also could use some more advance but the cost is $500 to get a rebuilt distributor, (which I don't need) I'd prefer programming it as it gives me control and the ability to change it. So, for me, there is a strong case to start putting a $ value on looking stock, yet have modern performance enhancing features. Anyone else starting to think this way? |
I don't think we have re-invented the wheel here. People fit igntions with programmable advance all the time to 911s. Others fit standard looking boxes that have no timing adjust. We are offering a product that is the best of both worlds - it costs a bit more. I welcome new products with open arms from the likes of Wevo, Elephant etc. They are expensive because of the time invested in development. It is the same for us, we haven't just knocked this up overnight, we've got two man years of development in this product. Folks regularly spend around $2500 converting to SSIs. They last a lifetime and release a few more ponies. I'd like to think our product will do the same! You are a tough crowd! |
There is a solid foundation for Porsche's move from CDI to Kettering. |
It is a fact that any CDI box Porsche '69 to '83 (and Turbos beyond that) is a valuable item that will be judged on a)originality and b) the quality of its parts when sold. We know for example that SSIs are not penalized when it comes to value. Why? They are good quality and fit just like standard parts. Same with Wevo etc. Often the stock parts are kept to go with the car. You hit the nail on the head in that you have to consider the true cost of the upgrade and like many the distributor is an unknown. As long as the main shaft bearings are ok, you can lock your dizzy and not have to worry that the weights are gummed up so no rebuild is necessary. You will also enjoy the 'soft limiter'. A noticeable reduction of power (by backing off the advance) rather than putting your head though the windshield! We all have older parts in our cars and if you're not careful you end up having to replace everything. Our CDI+ is designed to work with the older parts. It is not a vehicle for selling you a new coil, leads and distributor! |
Everything i state here is a result of REAL WORLD testing over the last couple of years.
Mr West, this thread is about the FUTURE of the CDI box.
You are clearly happy with the original CDI so this thread should really be of no concern to you. |
Thanks Jonny H for taking the time to answer and educate us.
For mapping the advance curve of a Turbo, it is crucial to be able to dial in retard based on manifold boost pressure. I have not seen that feature mentioned on your site. Can your unit do it? Thanks! |
on Pelican Parts in many threads, i.e. at rebuilding prices less than half of these so-called "modern technology" units. Quote:
that the fuel system still functions flooding the engine and exhaust system once the rev limit is reached. Do you have a problem using a 13mm wrench to tweak your 911 timing if necessary, i.e. if you really think Porsche's timing spec was inadequate? Quote:
achieve using a 13mm wrench if need be to advance the timing? Besides, today the octane values are less than what was available when the pre-knock control engines were designed, resulting in potentially a higher probability of detonation deviating from the Porsche timing specs. The key point, though, is that with the conventional ignition signals, i.e. points and a magnetic pickup in the distributor, little to no benefit can result in timing accuracy utilizing a microprocessor controlled timing function. The designs proposed are an over-kill with reduced reliability given the overall part count and complexity!
Dave Last edited by mysocal911; 01-03-2016 at 01:45 PM.. |
Functionista
The future is in repairing CDIs as it is relatively easy with non-potted units.
Or avoid the need altogether by using best practices. Keeping all connections clean, tight, and bright. Maintaining point and plug gap and change intervals to keep from stressing components. Using dialectric grease where necessary, etc.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
'73 911 T Targa
So, I'm wondering: Does the quality of the spark from a stock CDI box degrade over time? Should I consider swapping my 43 year old CDI unit for a more modern one? Is this a thing where advances in technology in the last 4 decades can result in improved performance, or is it a "if it ain't broke don't fix it" thing?
2. If your CDI unit is functioning properly, there's really no benefit in a so-called updated CDI designs. 3. There's really been no real advances in a CDI type of an ignition system and that's why all "modern" ignition systems no longer use a CDI system for automotive applications. 4. Yes, "if it ain't broke don't fix it"!
Dave |
I'm running modified zenith carburetors right now with a NOS 79 distributor. I have no means to do a fuel shutoff rev limiter. And I am using a Porsche rev limiting rotor, just like the factory carbureted engines. There is no means to do a fuel cutoff rev limiter. So sucking fuel on the overrun happens. Just like every stock carbureted Porsche of the vintage. Not going to lose sleep on that one.
I could tweak the 79 distributor weights and learn how to change the advance. I have managed a 13mm wrench once or twice before. I just don't want to. Right now I run 10 degrees BTDC idle, and the 79 has enough natural advance to get to ~28 BTDC by 3000 rpm. I think 33-35 BTDC might be closer to optimal. It would be nice to experiment, faster, with a programmable system. Or, I could sell the. 79, reinstall the 82 distributor, pin the weights and play with the advance. Then, in 6 years go back to CIS, take the rotor pinning out or leave it. My choice. |
Now that brings up another point about digitally controlled timing; What happens when the electronics controlling the timing fails, resulting in detonation? That is very unlikely with a simple distributor providing the overall timing. Remember, all the late Bosch ECU controlled ignition and fuel, e.g. DME units, do not operate in the high temp environment of the engine compartment as does the CDI unit.
Dave Last edited by mysocal911; 01-03-2016 at 02:16 PM.. |
