-   -   cold start csv location? (http://forums.pelicanparts.com/porsche-911-technical-forum/897745-cold-start-csv-location.html)
rubing 01-07-2016 05:37 PM
Car is a 77 911 with 79sc 3.0L engine. I'm having a bit of a cold start issue where the car sounds like it's about to start but requires a lot of cranking and time before it actually goes. I'm suspecting an issue with the coldstart valve can someone please point me to where I will find the cold start valve under the hood. I'm not used to working on porsche and don't know where to find it. any pics would help a lot...thanks!
KNS 01-07-2016 06:02 PM
It's not in the easiest location but it is accessible. You have to feel around the back, lower side of the air box. http://forums.pelicanparts.com/uploa...1452222140.jpg
rubing 01-07-2016 06:04 PM
YIKES!! OK well at least i know where it is. muchas gracias for the photo!!
KNS 01-08-2016 07:37 AM
I changed it on my 1980 SC with the engine in the car. It's doable. A slight engine drop would help. The picture doesn't show it but there is an electrical connector on the blue connection/thingy on the CSV. You push down on a little spring clip to remove if I recall correctly.
gomezoneill 01-09-2016 07:11 AM
I d check your control pressures first, highly unlikely the csv failed. A easy check is to make sure the connection on the thermo time switch are good it's on the left side timing chain cover. If you're not used to working on a Porsche the cis system is not a good place to start. I would see if there's a experienced Pelican close by that can help you out.
ossiblue 01-09-2016 07:29 AM
^^This^^
There are quite a few easy tests/checks you can do, even without checking the fuel pressures, to narrow down the area of concern. Don't jump to conclusions that the CSV is a problem.
I suggest you add to this post. Tell us exactly what's going on when you try to start the engine, and what you've tried so far as a remedy, if anything. Your problem has elements of several CIS issues so the more we know and the more feedback we get from you, the easier it will be.
75 911s 01-09-2016 07:39 AM
This may be useful for you, obviously you do not have a the throttle lever in the cockpit so you can ignore that.
Engine Fails to Start
you may also test the cold start valve
groovydude 01-09-2016 09:46 AM
I've been experiencing what could be similar issues. If I tap the gas pedal after I crank the key, it starts right up, but it's rough for about 5 - 10 seconds, then normal. I'd like to try this test, seeing if the valve clicks. Any ideas where terminal B+ is? Is this on the rear fuse panel or in the trunk?
