coils
regards, al |
farteeest
regards, al |
2.7 build
https://www.youtube.com/results?search_query=koz77911 regards, al |
Al, project looks great!!! Are you still using the Triumph Speed Triple throttle bodies?
When are you targeting your first fire? Quote:
questions
I chose 9.5:1 JEs because they provide higher compression without requiring twin-plugging. These pistons are good for carbs and EFI applications and have pockets deep enough for hotter cams. I really like early e-cams for their overall characteristics....so i chose a cam very similar to early E, but with higher lift more compatible with the larger 3.0 engine. combined with headers and sport exhaust...this is a great combo for the street/canyon carver.........it is a hot rod engine, but not over the top and over-stressed. should work fine and last a long time..... But that's just my preference....and I debate this stuff endlessly with my peeps........you might have a different use for your 911 and want higher compression, twin-plug,,,,much hotter cams etc.........lots of choices, but in my mind, you need to decide what you like/want .....and why....then define the system. |
Beautiful setup.
Are those coils fastened to the valve covers in any way? |
COPs
regards, al |
minor update
Installed the heater backdate ducts and the headers and adjusted the T'body linkage.........the last of the fuel plumbing fittings are due tomorrow and then i will move this engine to the test stand.......
http://forums.pelicanparts.com/uploa...1455690485.jpg regards, al |
https://patrickms.s3.amazonaws.com/p...d-Down-Tab.jpg |
If required, i think those would work very well.
Thanks. al |
I do not plan to use them unless necessary, but due to the height of the COPs, a longer stud or threaded space will be required............... anyway, not an issue at this time.......... regards, al |
Excellent job Al, as usual. Could you share, in round numbers, what the parts cost of such a project runs? This is the engine I'd dream of for my '74.
Thanks! -C |
This is just plain sexy!!! I can't wait to hear that motor in a car at full song!!!
~A http://forums.pelicanparts.com/uploa...1455690485.jpg |
Here's my kit on a very nice 3.2 tarmac Rally 911 (stock 3.2) originally located in Portugal (AlexJ on Pelican) and then sold to the guy who made the pro video. https://www.youtube.com/watch?v=enRgZ4FUNB4&feature=youtu.be https://vimeo.com/128026936 My S3-EFI/ITB kit installed on the 3.2 SS engine in the DZUG boys tour car in north Carolina.(headed for Sicily) https://www.youtube.com/watch?v=pxXwaL_TdmY https://www.youtube.com/watch?v=xaj0FyEmc68 regards, al |
Sounds EPIC!!!
~A Quote:
I want to stay up to date with this thread. how do I "subscribe"?
scroll up to the top of the page and in the upper right hand corner....click on 'Thread Tools" |
numbers
The numbers related to this particular build are specific to the new owner, but I'd be glad to discuss numbers with you, in general...if you will pm me with your email address. regards, al |
Great project, my question is, if you are running headers how are you going to use the backdated heat? Dave |
The headers are part of the test setup that I use on many engine builds. After building, I install the engine on my test stand and run it in and tune it up. The end user is installing SSIs on this engine. Here is the same setup being used on a previous engine and test run............. https://www.youtube.com/watch?v=EWB99lddFew regards, al |
That makes sense, I thought you had some new trick to run heat without heat exchangers. Thanks for clarifying
Exhaust
Andy http://forums.pelicanparts.com/uploa...1456166280.jpg |
chime
ready for fire......
I moved the engine to the test stand...The Rasant Engine management system is now installed and we're wired and plumbed and ready to fire with the following exceptions.......
IAT sensor install ....the IAT sensor is intended to be installed in a common plenum....with ITBs with no common plenum, i will have to be creative.......... The laptop that I use for tuning requires some updating to be compatible with the AEM Infinity ECU............. Install the latest tuning file................ Add fuel & oil More ....tomorrow..... http://forums.pelicanparts.com/uploa...1456295534.jpg |
Looking good! I'm expecting a video of course... :)
Tim,
Couple of last minute details to work out....and then.....fire. regards, al |
What will you do for filters? I used the filter housing as a handy place to put a hole to install a grommet for my IAT on my ITB MS3X install.
Pipercross filter socks will be used. i will make a cool bracket to mount the sensor in the appropriate location, while maintaining ITB functionality.
regards, al PS: others have taken this approach and, if required, have added a "rainshield" to the underside of the decklid...maintaining ...functionality and ITB/retro good looks, while increasing rain protection...if required. |
Does it make much difference where you position the IAT sensor? I mean - temps should be pretty similar whether it's right at the bellmouth, compared to in the general vicinity of the intakes?
Heatsoaks causes lean restarts and wandering idle RPM's. You can tune it out, but to me, it's better to find a spot that prevents it. |
Yes...thanks. Seems like a non-issue.
Al - first off that is a beautiful engine - amazing work. I hope when I retire out west in a couple of years I can bring the "Cruddler" down to your place to work your magic on it's 3.2. I just have a question on the exhaust and the general upkeep of this fuel injection system. Will the final product be tune it and forget it - meaning with the fuel infection and software will it operate like a modern fuel injected car? and secondly - I know this is probably not possible, but I suspect the test exhaust set up will have plenty of mid range torgue - my question is - with the proposed GT3 center muffler I wonder if it is much too free flowing for the application. Can the software deal with such a large change in exhaust set up? Has anyone run before and after torque / hp dyno runs? Not questioning your engine building skills, more interested in fuel injection system and exhaust upgrade Tq/Hp numbers comparo. Thanks
Engine is set up for Mid Range torque, Canyon Carver. As for Dyno numbers this will be done after I have installed it. The engine will be replacing a stock 2.7 Engine was spec'd to be a reliable, modern daily driver. After Andrew Darud posted his Rasant management system I was lucky enough to have peaked Al's interest in building the engine utilizing the Rasant kit. As Al has been saying it is going to be a very sweet Hot rod engine for the street. Andrew's kit pulls together proven components from various manufacturers. He and Al are great guys to deal with. Andy |
Al, You can make your own IAT using a single open element NTC thermistor. These are commonly available with different background resistance to match the calibration for the stock sensor in the Rasant system. I assume AEM has a calibration page to generate your own curve should you think outside the box.
The small thermistor is easily mounted inside your filter setup. This is how I ran for years with UNI filters directly mounted on my ITB stacks. The sensor could not heat soak as it was isolated from the system. You can run the wire inside the rubber sealing edge. For the education of everyone here. IAT placement does make a difference and depends on the algorithm used in the ECU. Most systems are designed around placement in ambient airflow. NA cars typically benefit from measuring ambient airflow temperature - either mounted in the engine bay next to cool air or directly in the intake tract (intake pipe, manifold, etc). In my experience the temperature differential between ambient and intake measurements are negligible on a NA car. This is especially true in a 911 where several thousand L/min of airflow exchange happen in the engine bay thanks to that marvelous whhhrrriiiinnnnnggg sound. :) boosted cars typically require manifold mounted temperature measurements due to the heating effect of compressing the inlet air. In this case, you have to apply a temperature correction to the fueling curve. The amount of correction is determined by how efficient your charge cooling is. And yes, heat soak can make a difference in running and hot start. Al is doing a great job. I am interested to hear his comments about tuning and software interface compared to the other systems he has worked with. |
I'm very interested in the interface too. In fact, I was going to ask Al to post some pics of the tuning screens. |
Good morning everybody and thanks for checking in...
Jamie...greetings. Yes, thank you...I have used thermistors for temp sensors with M'squirt systems and I've considered going that route. I am also interested in the user interface....and expect that we'll be discussing that aspect shortly. I will post screens as I go. I have successfully installed the AEM software on my laptop and I have the interface layout up on the PC....also applied power to the ECU...and a click of the AEM relay signifies that the ECU is active. However, I have a USB connection error that is preventing the ECU from communicating with the PC. Andrew and I are working on that and should have it solved this morning and then on to the next step..........last minute details. Stay tuned...I'll be back.... Note: I have grilles to ship today and another 3.0 on the engine stand that needs some CIS love...so it may be a day or two....work,work,work........but it is...fun. regards, al |
onward
I did get some time in today....and it was a good time. The communication issue turned out to be a simple driver issue.....
PROs: once loaded, the program came alive. I followed Andrews (Rasant) install instructions and was able to verify that the engine configuration was correct (pre-loaded by Andrew), set and verify the timing and adjust and verify the fuel pressure............these are the basic building blocks to first fire-up.... and the beginning of tuning. Andrew has also pre-loaded fuel/ignition maps based on the system in his car...and I will receive the latest version from him. The AEM interface is relatively straightforward for these initial inputs and the terminology is the same/similar to other systems i've used..........while i haven't spent much time with the dashboard...it does seem to contain all of the bells and whistles and looks very cool to boot...and i expect that it can be configured to meet the end users requirements/aesthetics, etc. These are bad pix taken directly from my laptop screen...but you get the idea... http://forums.pelicanparts.com/uploa...1456544716.jpg http://forums.pelicanparts.com/uploa...1456544750.jpg http://forums.pelicanparts.com/uploa...1456544769.jpg http://forums.pelicanparts.com/uploa...1456544783.jpg Note: The only con today....My stock Bosch fuel pump is from a mid-80s Carrera. I've used this fuel pump countless times ...it works great.....however, the capacity of my pump seemed to exceed the ability of the very nice Summit regulator to regulate and I could not adjust the fuel pressure below 70 psi.....yikes...the requirement for EFI is 40-ish psi and the Rasant instructions call for 39.2.....I had to significantly reduce fuel pump output to meet the spec. I'll have to check into this to verify the cause of the issue. |
Al, what summit regulator are you using? I have the black return style on another project with a 255lph pump and it has no issue at all. Summit Racing® Aluminum Fuel Pressure Regulators SUM-220066 - Free Shipping on Orders Over $99 at Summit Racing
David |
| All times are GMT -8. The time now is 08:03 PM. |
