Question on tires sizes for wide wheels, turbo body
Rear wheel is 17 x 11 (or 17 x 12?), tire is 315 x 35 x 17.
On the front, wheel size is 17 x 9. What tire size would you use? Thank you.
Fat butt 911, 1987 |
Slippery Slope Victim
255x45
MikeČ 1985 M491 |
I used 245/40. The 45 series tire looked too big and rubbed my AC lines.
1980 911 SC - Black on Red Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html |
I run a 245/40/17 on the front. (275/40/17 rear)
In a 245. when I compared the 40 to a 45 the numbers looked like this: 40 front = 24.71 45 front = 25.68 If you step up to a 255 like NY65912 suggested, check the diameter, likely sticking close to 25" I know many guys who run a 315 on the rear run a 255 up front. Not all manufacturers have the same combinations either. Nito NT01 comes in a 255/40ZR17 24.92" Hoosier R6 only comes in a 45 but diameter is larger 255/45/17 26.20" For reference, Nito lists these for their NT01 (the last number is the diameter) 255/40ZR17 24.92 235/40ZR17 24.40 245/45ZR17 25.55 255/40ZR17 24.92 275/40ZR17 25.55 P315/35ZR17 25.43
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
I stand corrected. I ran Kuhmo Ecsta XS 255/40 on my IROC look.
MikeČ 1985 M491 |
Member 911 Anonymous
See, I am not the only one using 40's :-P
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
245 or 255/40/17 will both work. Manufacturers will vary on widths. For instance my 255 Hoosier would rub the inside fender on a tight turn were my Kuhmos would not. Everything I've tried in 245's fit fine.
40 series is better than 45 series to avoid rubbing (on my wheel well), but it leave a big gap with the fender lip.
Does anyone know/care proportion between front and rear tire? I think it does affect the way the car drive and brake. How do they affect, what is acceptable, what is not. I read about it but forgot
Fat butt 911, 1987 Last edited by rnln; 01-13-2016 at 11:50 AM.. |
Are your wheels sizes 11" and 9" width? If so, I wonder how they look on the car. Do you have pics that you can post?
Thanks. Quote:
I have 255/40/17 on my 17 x 9 (or 9.5") right now. It looks fine, in term of tire fitting on wheel. I wonder how would 245/40 looks on the wheel, is it narrower compare to the wheel? Do you have pic of this set up?
A 245 will just be slightly narrower. Hardly noticeable. The photo shows 245/40 Hoosiers on a 930.
The fronts are 245 on 9s I had the rims built for the car so my centres are likely offset differently ( I know it is a 73 but the body dimensions are the same) ![]()
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html Last edited by wayner; 01-13-2016 at 02:10 PM.. |
thanks guys.
