74euroc's Avatar
oil breather connection '74 MFI
Newbie here. I was following the thermoswitch thread, and I removed my air box/intake (terminology?). underneath is the connection for the oil return flexible tube (top one on the oil filler). the connection to the underside of the air box is a plastic Tee - but one side is not connected to anything. I can't seem to see where it might go.
I wondered why this back section of the engine is fairly greasy....
thanks
lee farrell
1974 euro carrera, MFI
Old 07-15-2009, 03:35 PM
356RS's Avatar
The smaller line in that tee goes to the "oil drain pipe" bolted to the sheet metal near the flywheel. There is also a little rubber boot on the bottom of that metal "oil drain pipe". The part is about 4" long with a 1/2" ID. Has a small tab off one side to bolt it on the sheet metal piece. The top has the small connector for your oil drain hose that comes from the air cleaner box. That's most likely the missing hose and where the oil mess is coming from. I don't have a 74 MFI and it may be different than the earlier ones. Hope this helps.
Mark Jung
Bend, OR
MFI Werks.com
Old 07-15-2009, 04:26 PM
74euroc's Avatar
here's a picture
suppose I should ask if the small closed-off port is correct, also.
Old 07-15-2009, 07:57 PM
74euroc's Avatar
errrr
thanks for the reply. but....try as I may, I can't see anything within about 4 inches (if that's what you meant). I see a metal loop (what I would call a standoff), just behind the thermoswitch, as if a ~~1 inch tube would go through, seemingly then back behind the fuel pump assembly.
Old 07-15-2009, 08:10 PM
jphillips-998's Avatar
I just looked at mine and there is no hose on it. My engine has just been reinstalled by my shop so I'll double check with them tomorrow, but my guess is it's just a breather.
Jeff
'04 Cayenne S Hauler
'98 993 Cab
'74 Euro Carrera - SOLD
'91 944S2 Track Car
Old 07-15-2009, 08:54 PM
how about some pics of the car....mine was just in the historics diplay at the parade in Keystone.
Jeff
'98 993 Cab
'91 944S2 Track Car
356RS's Avatar
Thanks for the picture. The small single connector that has the hose clamp and is plugged is the line that goes to the oil drain pipe assembly. The small line at the tee in your photo is called the "flame arrester" and is open, nothing connects to it.
Mark Jung
Bend, OR
MFI Werks.com
Old 07-16-2009, 07:58 AM
356RS's Avatar
Picture of Oil Drain Tube less the rubber boot on bottom. The only part of the Oil Drain Tube you can see is the small tube connection that is sticking out of the right side engine tin that is next to the flywheel and covering the oil cooler. Just behind the oil thermostat as you are looking from the rear of the car.
Mark Jung
Bend, OR
MFI Werks.com
Old 07-16-2009, 09:53 AM
74euroc's Avatar
thanks again
- thanks again for the help
- do people put some type of filter/cloth/gauze to cut down on actual oil coming out of the tube?
- if the T is meant to be a breather, what is the point of the tube connection??
lee farrell
berkeley ca
1 photo here. a few more at: http://picasaweb.google.com/7T2PNTR (ignore the non-Porsche side project....)
Old 07-16-2009, 10:51 AM
356RS's Avatar
Inside that tee is a "Flame protection cartridge" part #901.107.729.00 This must have something to do with the other end being open. Must have to do with backfire issues. Porsche uses the same flame protection cartridge and same part # in the early CIS air filter box.
Mark Jung
Bend, OR
MFI Werks.com
Old 07-16-2009, 11:07 AM
74euroc's Avatar
is this the secret?
Is the reason I don't see the tube a) I'm an idiot (second choice, please) or that b) the tube is supposed to be where the horizontal hole at the back is? (this would be consistent with the port being blocked - they took out the tube.
see photo
Old 07-16-2009, 02:43 PM
356RS's Avatar
That's the hole alright. You have a missing part. If you can't locate the oil drain tube locally Lee, I will give you the extra one I have, N/C free.
Mark Jung
Bend, OR
MFI Werks.com
Old 07-16-2009, 03:34 PM
74euroc's Avatar
Thumbs up thanks for your generosity and posts
thank you Mark. I will do a little research locally first.
lee farrell
Old 07-16-2009, 05:00 PM
tharbert's Avatar
On my 72 MFI, I believe the smaller end of the tee goes to the charcoal container of the fuel evaporation system.
Old 07-16-2009, 05:15 PM
356RS's Avatar
Tharbert, That could be right. I'm trying to find more documentation on all the hose's connected to the air filter box. The fuel evaporation system lines connected to the 72 -73 MFI air cleaner box are not shown in my factory manuals.
Mark Jung
Bend, OR
MFI Werks.com
Old 07-16-2009, 07:22 PM
signature65's Avatar
you guys are corect. The Tee has the breather hose and the fuel evaporative line connected to it. The line comming out the bottom is simply a drain that runs to the drain tube on the front of the engine.
Darren
1973 911 T MFI
2005 997 Carrera
2001 Toyota 4Runner
Old 07-17-2009, 11:18 AM
74euroc's Avatar
holder for evap line?
could the "raised ring" in the photo carry the evap line across to the driver side? (picture is a little awkward - camera is tilter. the ring is NS oriented)
lee farrell
Old 07-17-2009, 11:42 AM
dtw dtw is offline
GAFB
No...that ring is for hoisting the engine when it is out of the car.
Beautiful car!
Several BMWs
Old 07-17-2009, 12:25 PM
max964t36's Avatar
Question Any definitive answer?
Hi, I was browsing for the same question but couldn't find any definitive answer for the small end of the "T" shaped connector ... thanks for your help!
Max
The last of the wild ones ...
Old 01-31-2016, 07:09 AM
