-   -   Steering column bushing question (http://forums.pelicanparts.com/porsche-911-technical-forum/898821-steering-column-bushing-question.html)
vick 01-16-2016 09:48 AM
So I'm pulling apart my steering wheel to replace my turn signal/headlight switch. Even though my wheel didn't have any play in it I ordered a Leland bushing to have on hand, figured I'd do it while I was in there. I get things apart though and find this...
http://forums.pelicanparts.com/uploa...1452966335.jpg
So it appears a previous owner already replaced the original with the slotted metal bushing option. Should I remove it and install the Leland? Worthwhile? Any difference? Not even sure how much of a pain it would be to remove, but if I'm going to do it now's the time.
Thanks!
JacobS911 01-16-2016 10:00 AM
I doubt you notice any difference and like you said there was no play before. You can replace it or just sell the extra one on hand. I'm sure someone needs one!
javadog 01-16-2016 11:13 AM
Well, it depends on how shot the bearing is. The stock bearing had a plastic sleeve that contacted the steering shaft. When those failed, lots of people replaced the plastic sleeve with a metal one that was a 928 part. If there is no relative motion between the shaft and the new metal sleeve, all is well. If the shaft rotates in the metal sleeve, it will start to wear the shaft.
I prefer to replace the whole bearing, but that's more work than you probably signed on for.
JR
Nick Triesch 01-16-2016 11:28 AM
Don't fix it if it ain't broke! It looks like the metal bushing from our host. I replaced mine a few years ago. Works perfect. Smooth with no play or noise. Why would the metal one wear out? Should last years.
sugarwood 01-16-2016 02:20 PM
If the wheel works fine, I'd leave it.
If it starts to fail, you can now remove the wheel in under 3 minutes the next time.
vick 01-16-2016 06:37 PM
Thanks for the inputs. I was inclined to leave it alone but tapped on the 928 part with a screwdriver, turns out it slipped out pretty easily. So figured what the hell and swapped in the Leland bushing. Fit is a little tighter but more importantly now there's no metal on metal.
