Anyone seen a Clutch set up like this?
Hi Pelicans,
Thought I would ask your opinion on this set up that I have just removed from my car last night. According to the many manuals, books and this forum that I reference on the engine strip down, the Starter Ring Gear should have stayed on, or be fixed to the flywheel? However, my ring gear is pinned/doweled to the pressure plate and it came off the flywheel as one assy. The clutch seems to be a standard Sachs type for this engine and was performing well (1977 2,7). Every Google search that I have done (as does the factory manual) shows the ring gear as part of, or fixed to the flywheel. There were no issues with the performance of this, so I am happy to refit it as it is. I am just intrigued to find out more because I really wasn't expecting it. Plus, I was looking forward to using the Flywheel lock tool that I bought! ![]() Some photos for you. Cheers, Jason.
1994 968CS 1977 911S 1969 MGB GT 1958 Norton Dominator |
Tap it off the pressure plate, it'll come off. It's just a close tolerance fit.
Bruce |
The flywheel without integral ring gear is stock OEM for a 1977, as well as some other years. Maybe you were seeing pics of later versions or retro-fits. It's not that unusual and our host lists the same type as OEM for 1977 911s.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Under the radar
This style clutch and ring gear started in '70 and continued through the SCs.
Thanks for you replies guys. That's the reassurance that I needed. I have time to get on with it today so I can have a closer look at it.
