Clutch Spring Install Tip
Can't remember where I found this tip so I thought I would re-post. Installing the clutch spring requires the strength of Superman.
Tip~ 1. Put the spring in a vice. 2. Flex the spring and push in washers between each coil 3. Slip the spring on! 4. Depress the pedal and the washers fall out. 5. Easypeasy : ) http://forums.pelicanparts.com/uploa...1453584077.jpg |
I like!
Great idea.
good tip, will be rebuilding my pedal assem.
Very good way to get it done quickly and safely than pulling it with a plier at your own risk if it fails and knock out your teeth!
great tip..I usually use regular 13mm head nuts....same difference.. it take 2 nuts or this on picture..
Ivan |
| All times are GMT -8. The time now is 12:26 PM. |
