'78 911 Coupe
Clutch Spring Install Tip
Can't remember where I found this tip so I thought I would re-post. Installing the clutch spring requires the strength of Superman.
Tip~ 1. Put the spring in a vice. 2. Flex the spring and push in washers between each coil 3. Slip the spring on! 4. Depress the pedal and the washers fall out. 5. Easypeasy : )
I like!
Great idea.
good tip, will be rebuilding my pedal assem.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
Very good way to get it done quickly and safely than pulling it with a plier at your own risk if it fails and knock out your teeth!
great tip..I usually use regular 13mm head nuts....same difference.. it take 2 nuts or this on picture..
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
| Tags |
| clutch arm spring , clutch pedal , springs |
