Non-resistor rotor part number?
After my upgrade to a MSD Streetfire ignition I'm in need of a non-resistor rotor. I called our host and they had no idea what I was talking about. Does anyone have the PP part #?
My local Napa is trying to source a EP407 rotor with no luck. Thanks! |
go to ********.com they got em. when u order there is a section where you can write a note. tell them to only send the black ones
Try Hawaii Import Parts, go there and ask them to see their selection of rotors, you will find one that works.
918 Ilaniwai St Honolulu, HI 96813 Kaka'ako Phone number (808) 591-2882 |
I tried them first. They also had no idea what I was talking about. Air Cooled Specialists had never heard of them either..
I'm on their site now and it looks like they are out of stock.
Echlin EB 407....just got one the other day at NAPA...btw, the pic shown in their online cat shows a resistor plug (generic photo) but the proper one did show up.
Napa online won't ship to Hawaii. I have a local Napa trying to source one but has not called me back so I'm guessing they gave up.
If they can't get it shoot me a pm and I'll buy/ship what you need.
same as a VW, I'm sure there are sum dub shops on the north shore
I'm going to take my current rotor to the parts house to see what they can match it to that is a non-resistor rotor.
Or, I have an extra you can use until you find one. |
Man shady for sure. Never thought it would be this hard to get the correct parts for my car..
http://forums.pelicanparts.com/suppo...s/pukeface.gifhttp://forums.pelicanparts.com/suppo...s/pukeface.gif Quote:
I made my own from a stock SC rotor. Dig out the resin and resistor and solder a copper wire across and you're good to go.
If it makes you feel better you can cover the "repair" with some two part epoxy. I used POR Patch on mine. |
The rotor you are looking for was never intended to be used on any 911 for any purpose. |
I took the rotor into Hawaii Import Parts today to have them match it up and they had ZERO idea what I was talking about and nothing that would work. All 5 guys working had never heard of a of a non-resistor rotor.
THANK YOU!!! That is exactly what I needed!
| All times are GMT -8. The time now is 08:35 AM. |
